Author Topic: What Battery .......... I'm confused  (Read 10651 times)
peter61_uk
  • Permanently Bewildered
« on: January 16, 2014, 09:42:57 pm »
Ok guys........ I've read some of these threads and I have to admit I'm proper confused about types of batteries, cells, chargers, wiring in parallel or series, run times and the whole enchilada.............
So fo a simple soul. I'm building a tug (it's my first go at this) ...... 84 cm Long, 18 cm Beam ....... I have  Permax 600 motor with a 3:1 Gearbox ...... Running a 45mm prop. (It was suggested that I change the motor for a 12v. But I have this one so that's what I'll use if I can).
So what type and size battery (voltage, amps etc) do I need that will give a reasonable run time in the pond ????
Peter
Re: What Battery .......... I'm confused
« Reply #1 on: January 16, 2014, 09:46:08 pm »
If it is a 6volt motor 2 x 6 volt 12 amp gell cells should be somewhere near.
You would need to ballast the hull and weigh the ballast and convert to the individual battery weight.
I do use gell cells as tugs require lots of ballast and these batteries supply power and ballast.
peter61_uk
« Reply #2 on: January 16, 2014, 09:58:54 pm »
Thanks Bob.......... The motor is rated for 7.2v. So, and excuse my absolute ignorance here, that'll give me 12v? or two lots of 6v???  ....... But I've seen some threads online where some run this Multiplex Permax Motor on 12v ????
Peter
Steven.T
« Reply #3 on: January 16, 2014, 10:03:16 pm »
You can get 7.2v NiMH batteries in a couple of odd shapes and sizes.
Take for example this one:
http://www.componentshop.co.uk/7-2v-3300mah-sc-nimh-battery-pack.html
A 3000mah battery pack, so technically at 7.2v you can draw 3.0 Amps from your battery for an hour. Obviously in the real world, you probably won't get this unless all your running gear is very efficient, or say you take it easy and draw less than 3.0Amps.
The higher the Mah of a battery, the longer it will last. If you have a 6000mah battery, and still draw 3 Amps, you can techincally get 2 hours of running. Make sense?
I don't think you would need to worry about running in series with a 7.2v motor. Series just means that you wire another battery directly in line with another. So the red wire from your ESC goes to the 1st batteries red wire. the black wire from this battery goes to the red wire of the second battery, and the black wire of the second battery goes to the black wire of the ESC. If you were using two 7.2v batteries, this would give you 14.4v, which is far far too high for what you want! Wiring in series keeps the Mah the same
Running in parallel means literally connecting the red wires to the red wires, and black to black. This increases your Mah, so two 3000mah batteries would give you 6000mah. Some people seem to recommend avoiding wiring in parallel like this, never tried it myself! Wiring in Parallel keeps the voltage the same however.
I hope this helps, if not, give us a shout and I'll try and explain it different. Once you get your head round it, it seems simple!
Steven
« Reply #4 on: January 16, 2014, 10:08:32 pm »
6 volts should be fine.
But ensure that the ballast to the waterline will support 1 or 2 batteries.
Minim batteries are fine but you will need lots of fixed ballast.
peter61_uk
« Reply #5 on: January 16, 2014, 10:19:49 pm »
Steven
Thanks Stephen ............... So, I'f I were to buy two of these 3300 batteries.......... I could run one in the boat and one as a spare ???
Peter
peter61_uk
« Reply #6 on: January 16, 2014, 10:24:51 pm »
I quite like the idea of the Nimh battery thing.......... and I was thinking, for ballast maybe using plasticine moulded into the inside edges of the hull and under the tray that'll hold the receiver and the one for the esc............... then paint it over.
Peter
Steven.T
« Reply #7 on: January 16, 2014, 10:45:30 pm »
Yeah, that's what I do, but I don't have a tug boat  :-))
Also with NiMH batteries, the larger the Mah, the heavier battery is. Take a look at some of those on the component shop website and see whats best. For example a 5000mah is 450 grams, where aa a 3300mah weighs 396 grams.
Obviously the larger mah the price goes up aswell!
Steven
peter61_uk
« Reply #8 on: January 16, 2014, 10:48:57 pm »
Thanks Steven ....... big help.
Peter
« Reply #9 on: January 16, 2014, 11:31:30 pm »
Peter,
In a tug you will need something far more dense and therefore heavy than plasticine.
Tugs require a lot of ballast to ensure the large prop is deep enough to not suck air from the surface.
What you use is immaterial as long as you can get her down to her waterline.
With a heavier battery this is removable so making the model that much lighter for recovery and transporting.
grendel
« Reply #10 on: January 17, 2014, 12:58:27 pm »
if you want to learn more about any type of battery, I would add this site to your reading list - http://batteryuniversity.com/
Grendel
Captain Povey
« Reply #11 on: January 17, 2014, 03:16:45 pm »
Hi Peter, I have three tugs and the only one with a NiMh battery is the St Canute which is quite small. The other two, Smit Nederland and Sun XX1 both use the gel lead acid batteries. Judging from the size description of your tug I would think it will need a lot of ballast and therefore a 6v 12h battery weighing in at approx. 2kg would seem to be a good starting point. Whether two are needed will depend on what amount of ballast you need in total and how much running time you want. Try putting the hull in the bath and loading it with bags of, say sugar, to see how much you need. I am not familiar with your motor and the current it draws at 6v or the rpm it does but I assume it is only a couple of amps even when turning that 45mm prop so I would expect 1 battery to be sufficient in terms of capacity for running time. It helps to know the current draw of you motor particularly under load as this helps you decide on the rating of the speed controller. Finally I would only ever use lead as extra ballast. I hope that helps. Graham.
grendel
« Reply #12 on: January 17, 2014, 04:25:31 pm »
it may be worth putting the bags of sugar inside plastic bags to avoid the sugar getting wet first - just in case - just to maintain family harmony.
Grendel
« Reply #13 on: January 17, 2014, 04:37:27 pm »
Grendel
 :-)) :-))  Thats's why I use Canned Food  {-) {-)
peter61_uk
« Reply #14 on: January 17, 2014, 08:50:04 pm »
Maybe I'll use the cat.........????? If I weigh him first, that'll give me a benchmark  :}
Peter
Steven.T
« Reply #15 on: January 18, 2014, 10:01:29 am »
Just remember you don't need to put the cat in a plastic bag like the sugar!
Captain Povey
« Reply #16 on: January 18, 2014, 10:34:24 am »
This cat was happy to act as ballast on the half built battleship until we got to the bathroom. {-) Graham
Captain Povey
« Reply #17 on: January 18, 2014, 10:36:07 am »
At this stage of a build cat ballast is too late. {-) Graham
craggle
  • Boaty McBoatface
« Reply #19 on: January 18, 2014, 09:04:00 pm »
In my tug, Model slipway Envoy I have two, 6 volt gel batteries. I still had to add a fair amount of lead sheet ballast under and around them too.
I managed to wire my batteries via a double pole, double throw switch so you can decide if you want the batteries connected in series giving 12 volts to the speed controller or in parallel giving 6 volts operation. In small areas it's far more controllable on the lower voltage setting and the 12v gives you another turn of speed when you want to race about in open water.
You do need to make sure the switch is in the right position when charging though so an interlocking mechanism was made ensuring you can only connect the 6 volt charger when the switch is in the 6 volt position.
Craig.
« Reply #20 on: January 18, 2014, 10:09:59 pm »
.....but perhaps not really needed with a 7.2 volt motor.
peter61_uk
« Reply #21 on: January 19, 2014, 04:49:22 pm »
Thanks all for your replies. It has helped a great deal toward me understanding this......... One thing that I'm still not sure about though...... I can understand the 6v lead acid / gel battery route. As well as powering the motor it'll provide some ballast...... But, will the 6v battery on a 7.2 volt motor mean much of a drop in power to the motor ???? Or is the 1.2 volt drop insignificant ???
Peter
Steven.T
« Reply #22 on: January 19, 2014, 05:02:38 pm »
It's hard to say unless you try it with a 6v then try it with 7.2v.
On my fireboat I had a 6v SLA battery, the boat didn't quite plane, changed it for a 7.2v NiMH, and it did make it up on the plane. It all depends on the boat and what you want out of it!
peter61_uk
« Reply #23 on: January 19, 2014, 05:05:35 pm »
I just found the spec on the Permax 600 motor:
SPECS: No-Load Speed: 17,600 rpm
 No-Load Current: 1 Amp
 Maximum Current: 28
 Current at max efficiency: 10 amps
 Typical operating voltage: 6-12
 Shaft diameter: 3.2mm
 Weight: 8.1oz
I have this on a 3:1 Gearbox.
Peter
peter61_uk
« Reply #24 on: January 19, 2014, 05:07:15 pm »
Well, it's a tug ........... So planning wasn't really in my gameplan for it Stephen  :}
Peter
