Hi Peter, Well I use gel cells as they are a form of lead acid battery but unlike the car or motor cycle battery the electrolyte between the lead plates is not liquid but a paste. Therefore the battery can be used on its side without the acidic electrolyte running out. In most of my bigger boats I use a separate battery pack for the radio and do not use the battery eliminator circuit and the weight of the extra batteries is not a problem. In a couple of smaller boats where space is a problem the use of one battery can be useful. Its probably a bit old fashioned to use a radio battery and a motor battery. Basically the bigger the Ah the more running time you will get so 6v 12ah would be good. The running time will depend on the current taken from the battery when running under load so it would be good if you could measure the current drawn when running the prop in water. Your motor spec mentions 1amp but this could rise to 4 amps or more under load i.e with the prop in water. Even so with a 12AH battery you would bet approx. 3hrs running time. Graham
Good Stuff Graham ........ Component Shop have Sealed Lead Acid 6v 12Ah Batteries for £11.65 ....and with the dimensions, I can probably get away with one standing upright (and it'll give me 2kg of ballast
) .............. I'll do some mooching around on the net for gel batteries.
