Author Topic: Workshop heater  (Read 7172 times)
Re: Workshop heater
« Reply #25 on: January 25, 2014, 09:12:34 pm »
I use an oil filled radiator in my small shed and once it warms up it is fine. Nor is it always on power as it has a thermostat. What I like best is that if I go back into the house for an hour I don't worry about leaving it on and burning the shed down.
Nordlys
Re: Workshop heater
« Reply #26 on: January 25, 2014, 09:28:16 pm »
That is exactly my biggest concern next to fumes - leaving the burner
on, even for the shortest trip back into the house. Its not so much a problem to turn it on & off but the temptation to leave it on is too risky.
I intend to pick up an oil filled rad with thermostat next week.
Thanks Dave.
N
Captain Flack
Re: Workshop heater
« Reply #27 on: January 26, 2014, 10:57:02 am »
I have a "black tube heater" in my workshop which I leave on all the time.   Keeps the chill out of the air and is supplemented by a fan heater when needed.
Re: Workshop heater
« Reply #28 on: January 26, 2014, 11:23:15 am »
   Fork handles                                           %)
Brian60
Re: Workshop heater
« Reply #29 on: January 26, 2014, 12:29:24 pm »
I can say that today is warm enough for me to work outside albeit it is blowing a gale. Its actually colder in the house than it is outside at the moment- typical of spanish houses, built to keep the heat out and not in!
Re: Workshop heater
« Reply #30 on: January 26, 2014, 12:32:04 pm »
   Fork handles                                           %)
You would get more heat burning fork handles  %% %% %% %%
barriew
Re: Workshop heater
« Reply #31 on: January 26, 2014, 01:10:31 pm »
That's my method also, although I also have a small wall mounted convector I sometimes use after getting the temperature up with the fan heater.
Barrie
Nordlys
Re: Workshop heater
« Reply #32 on: January 26, 2014, 01:27:06 pm »
Do these "black tube heaters" work simply from an electrical supply or is there gas involved?
Not something I have come across.
N
Re: Workshop heater
« Reply #33 on: January 26, 2014, 01:35:08 pm »
They are low power enclosed electrical elements used to keep greenhouses frost free etc.
 http://www.tlc-direct.co.uk/Products/PHGHTH4.html?source=adwords&kw=&gclid=CLmOwfL5m7wCFcXItAodhjoAjg
In a workshop they would be useful to keep the damp out but will not give you a comfortable working temperature.
Nordlys
Re: Workshop heater
« Reply #34 on: January 26, 2014, 01:53:12 pm »
Thanks Colin, I thought you would know.
When greenhouse was mentioned, this heater sprung to mind.
I certainly need more than that to heat my 'workshop' -its getting so
damp in there this winter I've had to cover my machinery and bring in certain
other rust prone items of tooling.
Thanks all.
N
Page created in 0.599 seconds with 21 queries.
