Thanks Mick - I am trying various ways to get the planks firmly attached just where I want them. At the moment I am just using the CA and lots of finger pressure to keep things in place until the glue grabs of its own accord. This gives me a short while to adjust the position of the plank and confidence that it isn't going to move just as the glue takes over. It also gives me aching fingers.
Well, I decided to work at the side/bottom planking joint from both directions at once. At the bow, the two plank layers must obviously butt together to give a neat, straight join in line with the chine. Further aft the two layers overlap at approximately 90 degrees, the side planking covering the edge of the bottom. That long section is easy, and I sanded the bottom planking flush with the side up to the point where I felt a transition was going to begin. I then marked the line of the chine along the planking to the bow and started to cut the bottom planking along this line starting at the bow. Here is a picture of this process beginning.
You don’t have to know a lot about building this boat to see that there is a bit of an issue with that plank in the middle of the picture. It doesn’t lie flat on the hull and I have accidentally cut too much off leaving a nasty gap.
I fixed this by chamfering a piece of scrap and gluing it in the gap under the plank.
I then trimmed it off and carried on cutting the line back towards the point where butt joint becomes overlap joint. I crept up on this point from both directions and ended up with a transition that I think allows a reasonable run of the first side plank along the chine. It really doesn’t look very pretty at the moment, but I hope a little filler and a lot of sanding will leave a presentable finish. Time will tell.
While trimming the lower bow, I discovered another point where the gluing wasn’t too good, and I broke out a piece of planking
Rather than try and glue the broken piece back in, I decided to just cut out the damaged area and glue a solid block of mahogany in to replace it.
The bottom has had a preliminary scrape and sand and already looks slightly more presentable.
I seem to have spent a lot of time fixing little things I didn’t do right first time.
Having got past the tricky planking join at the bow I hope the sides will go on nice and smoothly – but I’m preparing to be surprised!
As a bit of a diversion from the trials of planking, I have been playing with my dummy section of deck to see what sort of finish I can achieve –
That’s encouraging.
If I can repeat that over the whole boat I’ll be happy. (It’s two coats of epoxy, five coats of yacht varnish, wet sanded to 1200 then polished with
this.)
I am happy with the progress so far – I always viewed this as a year’s project, although I hope to get to the final painting, varnishing and finishing while the weather is still good for outside work. Of course that could be any time from August to October!
Greg
