Author Topic: False keels...  (Read 2437 times)
U-33
  • K-157 Vepr. Akula-11
False keels...
« on: January 31, 2014, 11:38:46 am »
Slight change of plan, instead of building the Glynn Guest Avispa, I've ordered another Tamiya USS Enterprise carrier. I made a right cock of the first one, I put far too much stuff in it, and it ended up so unstable I couldn't use it, it even fell over in the bath.
I don't want to do that again, so this one is set to have a false keel fitted. I'm thinking of making a perspex keel, similar to those big old fashioned yachts had fitted to them...maybe half the keel length or so, and a couple of inches deep, cutting a slot in the hull and pinning and glueing it in place.
But before I do, any more suggestions, chaps?
JayDee
    • JOHN DOWD
Re: False keels...
« Reply #1 on: January 31, 2014, 07:05:30 pm »
Hello Rich,
Could you fit an keel to the one that "fell over"?.
Try it, easier than building another boat, - - that may require a keel fitting !!!.
John.
http://www.john-dowd.
raflaunches
  • The Penguins are coming!!!
Re: False keels...
« Reply #2 on: January 31, 2014, 07:22:51 pm »
An interesting solution I saw several years back on the same kit was a scale model of a submarine was filled with lead and glued to a Perspex fin to create the counter balance to the top heavy aircraft carrier. It was a different idea and worked quite well on the swimming pool the modeller was sailing on. I believe that it was detachable too for ease of transport.
Nick B
Illegitimi non carborundum!
U-33
Re: False keels...
« Reply #3 on: January 31, 2014, 07:31:00 pm »
Hello Rich,
John.
Bit awkward that, John...I gutted it and sold it to a chap who wanted it as a static display model.
Good idea, that...but I've had enough of submarines for the time being.I'm taking a sabbatical from sun dodging...
