Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: LOS ANGELES build logs  (Read 51394 times)
Re: LOS ANGELES build logs
« Reply #125 on: April 16, 2015, 12:58:40 pm »
Are the standard off the shelf shell of the individual pop rivets not aluminium? :o...or are brass/bronze shell with a Grade 316 shaft available?.............Derek
profesorul
« Reply #126 on: April 16, 2015, 04:46:22 pm »
HI DEREK ,
I'm Sorry but I don't understand Your question !.
Can You Rephrase ?.   :}
MARIUS
profesorul
« Reply #127 on: May 24, 2015, 05:53:22 pm »
HELLO There ,
I progressed a little work on the submarine. ...
Not having a laser level or other modern means of marking curved surfaces , I have found a way to draw a straight line inside the lower hull .
I did like the following:
On the exterior of the lower hull I had the axis allready trased – axis used to draw the flooding holes ...... I made a few very small holes along this axis , I’ve passed a more resistant rope inside the submarine , I caught as stretched out as I could at the ends , and on the other holes I made a connection to the outside as seen in pictures .
In the end I’ve put a few drops of glue on each link
then I moved to the next stage of the work consisted of making a bronze bushings have inside a 6mm hole for propeller shaft and a small flange at one end.
Flange and also will be a stop on it will slip when the propeller rotates.
Bush I did - a smaller more remain outside as much as in material thickness will give aft cone when the hole for attachment.
I found a shaft 6mm long enough, worked extremely fine (it was to a printer) at one end which I did a 5mm thread for the adoptive propeller and screwing nut
And the last step :
- not having such thick material for WTC supports - and two component resin is very expensive here , I chose to do each support from light pvc , four layers of 2 mm glued , pressed and procesed on lathe - as seen in pictures .... a job that is extremely messy ,
MARIUS
« Reply #128 on: May 24, 2015, 07:08:43 pm »
dont  know if you alrerady have all the WTC etc.,but there is a lot just came up on flea bay Los angeles specifically mentioned
Jay
http://www.ebay.co.uk/sch/i.html?rt=nc&_sop=10&_nkw=radio+controlled+boats&_ipg=200&_geositeid=3&_trksid=m194
cos918
profesorul
« Reply #130 on: May 25, 2015, 09:02:11 am »
THANK YOU both , but I already have most of the stuff .
Not to mention that my wallet is so dry !   <:(
I'm struggle to make from time to time some progress with it .
MARIUS
profesorul
« Reply #131 on: May 27, 2015, 12:44:56 pm »
And for the moment these is all I can make :
until June 22 , I wont be in town so is going to be a pause in construction .
MARIUS
Pages: 1 2 3 4 5 [6]   Go Up
