Hi John
Sounds like a plan, try contacting Mudway here on the forum as he has been conducting in-depth tests using different prop/motor/battery combinations using one of my 1/24th scale BPB MGB hulls and he may be able to offer you more advice on the subject. For example one tip courtesy of his testing is to be careful the skegs are not too close to the props otherwise you will get cavitation on the sharper turns with certain props. Also note 3-blade props may improve slow-speed work and reverse operation.
A quick bit of history for the tests. 3 of us are building Christian’s semi kit for the 71’ 9” MGB. People I spoke to in the UK recommended the Graupner 600 Eco and a 35mm 2 blade prop.
I bought what I thought was a 600 Eco from a UK model shop which arrived in a plastic bag with a black & white Graupner attached to it rather than the usual Graupner box with instructions etc. I asked the shop what it was, and they never bothered to reply. What I got sent was a Mabuchi RS550 in a Graupner bag. Finally got an original boxed one made by Graupner and tested that.
I was surprised by how many amps it pulled but put it in the water. Nice and fast but, with a 2 blade prop, would not stop at all when an idiot yachtie went straight across my bows. Didn’t hit him but scared the hell out of both of us.
After that I went and test tank tried a Raboesch 30 & 35mm 3 blade WW2 style prop. Much better. Nice and fast on 8.4 volts & very fast on 9.6 volts.
Then one of the guys in the club mentioned Glynn Guest’s article on crawler motors. I had a read and bit the bullet and bought one. Much better, more rpm and less amps. The Integy one I have been testing is a 12 volt motor compared to 9.6 for the Graupner/Mabuchi. On the MGB, the 35mm seemed better suited to the hull.
I did actually try it with 10.8 volts in the water and the boat went like stink. So much so that I wasn’t game to try it on 12 volts. Sucked too many amps anyway.
I did also try a 45T and a 65T Crawler by Integy but the 45T just pulled too many amps compared to the 55T and the 65T just didn’t give enough rpm in the water.
Two shots attached from yesterday when I got to run her in calm water. As you can see, nowhere near built yet. I never glue a deck down until I’m fully satisfied about how the model performs and turns. On 9.6 it actually maintains its speed in a turn, on 8.4 it slows down.
