Author Topic: The SEAPOD: command(order) azymutale of pod, z-drive small-scale model on 360  (Read 9024 times)
GAZOU
EXCLUSIVELY FOR THE BLUE FORUM
Exclusively for the BLUE , to GAZOULAND a French manufacturer is going to propose you the first French module of management of pods on 360 °
Simpler, more logical, less cumbersome..
GAZOU
Much simpler in his principle
Reproduced exactly the reality
Finalized with the assistance of professionals of the towing
Presentation, demonstration, essay of the public on May 30th, 2014 to GAZOULAND *
*Gazouland, the party of the French forum, friend of Mayhem
steve mahoney
I'm interested.
GAZOU
Hello
You go to know more about it to a few days.
You go to be surprised by the simplicity of the system.
Ideal system for tug boat and beg in the oïl ( supplies )
GAZOU
Hello
For information , Video in a few days
SEAPOD
The realistic pod control for scaled pod models
·         Pre-wired, no possible connection mistakes
·         Uses the electronic of the remote control
·          Can be steered with two fingers
·         Only one stick to control everything: thrust/rotation
·         Suitable for every types of remote control expect pistols
·         Suitable for every types of motors : brushed/brushless
·         Suitable for every variators/controllers
·         Initialize automatically when the remote control starts: stop engine, steering at 0°
·         The pod steers exactly at the speed ordered by the remote control
·         The pod reacts exactly to the degree, according to the stick orientation
·         360 degree rotation any direction, as many times as ordered
·         Fine tuning of the throttle without releasing the stick
·         The thrust reduces automatically at 90° and at 270°
·         The pod stays at the last order information given while waiting for a new order
·         Minimum volume:  5cm*5cm (1.97 in*1.97 in)
·         Warranty by replacement based on the date engraved on the case
·         Price clearly under the competition
·         Demonstration and trial with a test model on Friday May 30, 2014 at GAZOULAND
GAZOU
This system is equipped with a BEC crossing(spending) 1,5 Amph
He(It) is totally tight in the dust and in the water
Amateur video of the prototype
http://youtu.be/kM7zekqxkwA
The material is delivered with all the plans and a note completes in English language
Umi_Ryuzuki
    • Models and Miniatures
Je suis intéressé ... curieux
GAZOU
Hello
That want to come out?
We are for your service  for all the information
GAZOU
Here is a video we see the handle which manages the pod we see the command(order) of gases
The prototype is executed in 3D but the definitive will be aluminum streaked
http://www.youtube.com/watch?v=tVPe5cZal6w
GAZOU
 Bonjour ,   HI !
Here is a photo of the module SEAPOD
I go to UK in a few weeks.
 I have to visit some friends designers, I would show the module to my friends.
The green led indicates the switched on of the system (12 volts), the red led indicates the low(weak) battery(drum kit).
The system is any cablé, no weld to be made, it is plug and play
It is the ideal system to command tug boats ASD
Jean-Pierre GAZOU
Looking good!  :-))
GAZOU
Topic renamed.
GAZOU
Hello the lads
Here is the SEAPOD ready to be installed in a model of tug boat SDM.
Two units will be needed because there are two propellers.
It will be enough to connect the pod, the engine of position (plug yellow) and the sensor by a notched belt so that it is fit to work.
You position the pod with zero
You connect batteries, the green led ignites
You initialize the system by pressing on the small button (hole in the boitier)
You will find the zero automatically in every starting.
The pound gives you the size
GAZOU
Hello here is Seapod ready to be installed in a tug SDM
Two Seapod is needed because there are two propellers.
By unity :
It will be enough to connect the pod, the engine of position and the sensor by a notched belt so that it is fit to work.
We connect the sensor (taken yellow Position)
We position the pod with zero
We connect batteries (plug brown Bt) the green led ignites
We initialize the system by pressing on the small button (hole in the case)
We find the zero automatically in every piece of news put back in action
The pound gives the dimension  of the module.
Thickness two and a half centimeters
Here are the possibilities, for the pleasure (later of the training) {-)
http://www.youtube.com/watch?v=FjuA5eoE_Xg
Umi_Ryuzuki
I am still not clear how it will achieve something similar to this video....
http://www.youtube.com/watch?v=OHN9-RssyOc#t=16
If the unit requires Horizontal and vertical from two joysticks, where
will the throttle channel come from for each drive?
GAZOU
On this video you have two sticks which you do not see.
But who exist!
Right left by moment, with the mixing of the radio we can make turn pods independently in different directions or in the same direction .Avec her throttle control the speed of (one) the propeller is adjusted? It is also mixed by the radio .
Vous know that it is impossible to make as the video, with a single handle and without radio mixing of both handles. It is idem with the SEAPOD
The engineers, to follow a designer who moved forward an idea, tested a variant. They fell behind the initial program because of it .Mais, at the end of this week you will have a video on which you will see the SEAPOD in action(share).
There are two possible modes(fashions):
A mode with vertical / horizontal + gas which allows to master well gases on 360 °, it is the mode 1 three ways are occupied
A mode with vertical / horizontal and the slope of the handle gives the volume of gases onto 360 °, it is closer to the reality but more difficult to master the volume of gases on 360 °: it is a radio control ..................... it is the mode 2. Two ways are occupied.
It is the computer which makes the work.
The engineers study a lever similar to the reality.
Obviously it is voluminous, and it has a high cost of manufacturing. It will be an option
A TUG SDM is under construction, the hull will be molded on Wednesday.
A demonstration in navigation will take place at the beginning of May during the "GAZOULAND" which is the equivalent of the MAYHEM show to WIKSTEED .
Best regards
Umi_Ryuzuki
I know there would be two joy sticks,
But that is only four channels.
I am guessing that the vertical axis is split with a "Y" connector
and plugs into each(2) seapod  as throttle(G) and vertical(V) then?
Vertical - V = one channel on reciever/tx
Horizontal- H = two channel on reciever/tx
Throttle - G = third channel
For a second Drive...
Vertical - V = fourth channel on reciever/tx
Horizontal- H = fifth channel on reciever/tx
Throttle - G = sixth channel
There is something that I am definitely not comprehending correctly.
 :o
GAZOU
Hello
No, no cordon Y
4 channels mode 2
For the right pod to connect you Vertical / horizontal you have the functions rotation of the right pod / gas
For the left pod you connect Vertical / horizontal you have the functions rotation pod / left gas
If you have a mixing the pod mastercommands(orders) both pods if you connect the function mixing to go straight ahead for a long time (make road)
Here is a video made very quickly on the corner of the table
http://www.youtube.com/v/QUTMvV1AmnE
mode 11
Gases are at the end of the handle ( supplied kit) you use 6 ways, three to the right, three to the left
The management of gases is more fluid
Each can pilot according to his préférences
Umi_Ryuzuki
It is a better understanding through your latest video.
One of my concerns was that the other video has modified the joystick on the transmitter.
And that was something that I would want to avoid. The seapod is still a mysterious
black box, but it would appear to give the control of Zdrives in a very good way.
 8)
GAZOU
Hello
The engineers prepare a very clear note
It will hold on a page (there are only 6 threads to connect)
In the mode 2 there is no modification of the transmitter
In the mode 1 it is necessary to connect a proportional way with the rotacteur down from the handle, there is a grip to be moved and 4 screws to be positioned on the case
It is really a very simple system.
The engineers are studying a lever as on the truths but, obviously, it will have a cost. It will be an option.
Page created in 0.039 seconds with 21 queries.
