Go gas...
1. be clean
......the quality of flux is also critical....be clean
2. un-soaped steel wool is preferable to aluminium oxide or carborundum paper when cleaning [the effect of the latter looks shiny, but leaves a dust residue] after cleaning, do not touch a cleaned joint section with your fingers
...skin contain grease .....grease does nor solder well
3. heat the area surrounding the joint.....not the joint itself
4. kitchen tissue saturated with water is a good heat-sink as are metal clamps.....when soldering in close proximity or a pre soldered joint
5. a kitchen hand held water spray pump pack can be handy for quick cooling
6. a few pairs of surgical forceps' are very useful in holding small objects
7. plenty of heat capacity from a micro pencil to a large torch......you don't need luck.......just practice
8. an old large refractory brick is also very useful as a work bed
...be clean..... Derek
