Author Topic: Cleaning brushes  (Read 1697 times)
james1102
Cleaning brushes
« on: March 13, 2014, 12:47:27 pm »
What is the best way of cleaning brushes after using sanding sealer
James
cdsc123
Re: Cleaning brushes
« Reply #1 on: March 13, 2014, 02:05:24 pm »
The most effective and economical/environmentally friendly way I have recently found is to use a flat tin like Cafe Creme small cigars come in, pour in only a small amount of thinners/brushwash/acetone, to a depth of about 2mm. Holding the brush firmly push it down against the base at an angle whilst rotating the handle, this will very quickly clean all the fibres leaving only a small residue in the ferrule which once dry will prevent hair loss next time you use it. Quick wipe with a kitchen towel and done. Dispose of the residue using the same towel, leave it to evaporate.
SailorGreg
« Reply #2 on: March 13, 2014, 06:19:10 pm »
Alternatively, if you only use the brush for sanding sealer (and having used it for SS, I wouldn't advise using it for anything else that matters), don't bother to clean it at all.  Yes, it will go hard, but next time you want to use it, pop it into the SS for a minute and it will be back to its nice soft state ready for use again.
Simples!   ;)
Greg
james1102
« Reply #3 on: March 13, 2014, 07:41:44 pm »
Thanks for your suggestions
Page created in 0.557 seconds with 17 queries.
