Author Topic: Hobby King 2.4 Mode 2  (Read 2977 times)
Big Ada
« on: March 19, 2014, 05:48:30 pm »
Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)
[/t][/t][/t]
HobbyKing 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)(THROTTLE ON THE LEFT) Hobbykings T6A 2.4ghz system is an entry level transmitter offering the reliability of 2.4Ghz signal technology and a receiver with 6 channels.This transmitter requires a PC to modify any of the channel variables including mixing and servo reversing. Key Features;
6-channel 2.4GHz transmitter with servo reversing.
Easy to use control for basic models.
Includes 6-channel receiver
Trainer system option.
This system must be programmed via PC cable. Included;
1 x 2.4Ghz transmitter
1 x 2.4Ghz Receiver
1 x Bind Plug.
Note:
Only HK-T6A receiver is comptible with HK-T6A transmitter.Only HK-T6Av2 receiver is compatible with the HK-T6Av2 transmitter.
PRODUCT ID: HK-T6A-M2
Leonard 6 points - 3/18/2014
I bought the above mode 2 Tx and several RXs to update my fleet of RC Model boats, however I am having trouble and need help please. I went through binding = Insert Bind Plug into Battery socket on Rx then insert Battery ( 4x AAs) in to any other socket on Rx ( it says 2 leds flash, Only 1 flashes on my Rxs, maybe translation error? ) then press and hold in Bind button on Tx then turn on Tx and the flashing Led stays on. Binding done remove bind plug and battery then connect servos and esc,   Turn on Tx then Rx and then the Rx flashes  once and nothing works, if I switch it all back off and leave for a while, at least 30 minutes it may work when I switch it all back on, some times I switch it off and leave over night then it will work. If I sail my Boat and then take it off the water and switch it off I want to be able if needed to be able to switch it back on and sail again. Over to you guys, from a VERY frustrated  Len.
                                            Ignore the REPLY button as I posted this on HKs Site and got no replies, so I am hoping to get help here.Thanks.  Len.
[/td][/tr][/table]
Big Ada
Re: Hobby King 2.4 Mode 2
« Reply #1 on: March 19, 2014, 05:50:56 pm »
When I copied and pasted there was a Picture of the Tx.
black magic racing
  • when winning is all . it stops being a hobby
« Reply #2 on: March 19, 2014, 07:12:50 pm »
hi.ok what i would do is rebind it at again,fully charge up the batteries and take all servo leads out,plug bind plug back in then battery and then do the bind on the tx,but when you do this make sure tx is as close to the rx as possible.make sure when you are binding that rx led is flashing befor bind and is full on when binded.now what i would then do is if unplug bind plug and battery,then plug battery straight into rx without using your on/off switch,,now check to see if the rx staying on?hopefully it will do,now plug all the servos in and try the tx ,if all is working,take the battery lead out again and re plug it in so that you have turned off the rx and back on again,is it still working?,if so,then using your on/off switch plug that in and your battery into the switch now try again,is it working? if it is, turn it off on the switch and back on again and see if it is still working?if not then switch it on and off a couple of times with the switch quickly,does it come on ?iv had this problem and it was the switch playing up lol,but the only way round it is to rebind with the battery pluged straight into the rx,hope this helps,abit long winded i know but give it a try,,,,regards   kurt and sha :-))
FAST is never FAST enough
Black Magic Racing with BMPRS    Telford Model Boat Club
Birkenhead Model Power Boat club Vice Commodore
