hi there Geoff
Are you building the Cervia from a kit or is it a readymade hull; or are you making the Cervia from scratch - as in the masterclass build. The reason I ask, is that 36 inches overall seems an oddball length as a 1:35 scale should work out at 38 inches roughly. I think 1:24 scale works out at about 28 inches - but that is just a thought.
As a 60 mm prop does seem on the large size for the hull. I seem to recall when I built the Cervia it was either a 45 or 50 mm brass prop that I used. To drive this, I used the MFA belt driven gear box but sadly MFA dont produce these gearboxes any longer. You can still get them though if you shop or hunt around Ebay and such good places.
The motor I used was a 540 pretty high revving one on 6 volts. As another side note
the motor Dave is mentioning on the thread above, if its the same one or the same style as Dave supplied to me when he owned ACTion - it will do the job fine cos I have this type of motor (direct drive) in the Archer Tug which I built - it drives a 50 mm 4 blade prop using a 7.2 NiCad battery.
Food for thought my mate.
aye
