Author Topic: Drive belts  (Read 2784 times)
Sandy
Drive belts
« on: April 12, 2014, 05:25:33 pm »
Not sure if this is the correct place to ask, but where is the best place to get drive belts and gears to connect a motor to a shaft ?
I have looked at the Motionco site but I am a bit unsure regarding the diameter of shafts.
Do any of the model boat suppliers do 'sets'?
All the best
Sandy
Re: Drive belts
« Reply #1 on: April 12, 2014, 05:31:20 pm »
TomHugill
Re: Drive belts
« Reply #2 on: April 12, 2014, 05:49:39 pm »
Try therse, very helpful and can do none standard work
http://www.hpcgears.com/products/pulleys_belts.htm
Re: Drive belts
« Reply #3 on: April 12, 2014, 06:45:50 pm »
The spec sheet with the motor should give the output
shaft diameter.
The prop shaft will either be 4 or 5 mm diameter.
normally.
If you have already bought motor and shaft you should then
have to decide on the ratio I.e. 2:1 or 6:1 or whatever.
16-21
Re: Drive belts
« Reply #4 on: August 13, 2014, 01:03:51 pm »
SHG modelling supplies,
Recommended by Brian at mobile marine models.
Beautiful alloy toothed pulleys,
Great advice as well from SHG
TomHugill
Re: Drive belts
« Reply #5 on: August 13, 2014, 01:57:25 pm »
Have they got a website Adam?
Re: Drive belts
« Reply #6 on: August 13, 2014, 01:59:50 pm »
Yes Tom,
Shgmodellingsupplied.co.uk I think
Or just google it...
There is not much info but if you phone them they are sending out new catalogues soon I believe...
Speak to Susan if you can,
Adam
Page created in 0.219 seconds with 21 queries.
