Author Topic: Forum News, Announcements, Updates, Errors, etc.....  (Read 1085909 times)
raflaunches
  • The Penguins are coming!!!
Re: Forum News, Announcements, Updates, Errors, etc.....
« Reply #1225 on: January 12, 2019, 06:35:37 pm »
Well done Martin
Thought some thing was wrong when I couldn’t even get the Mayhem homepage up! Always worrying when things like this happens- as Bob says I was getting flu like symptoms from the withdrawal! {-)
Nick B
Illegitimi non carborundum!
coch y bonddu
« Reply #1226 on: January 12, 2019, 07:29:09 pm »
Has Mayhem been down today?
Excuse 6.3.1
I run a full Mayhem server backup last night .... 16+ Giggle bytes... yes 16.3Gb..... count them!
Anyway it creates a 16Gb.Gz (compressed) file on the server which you then download via SFTP, but the generated file doubles the disk space in use..... obviously!   This overshot my server space limit - by about 40%,  causing the server to lock up... Mayhem stops responding
"Clean up on isle one please!"
All sorted now.   :-))
.....  Sorry for the delay, had to work today  .... sigh!  {:-{
 Mar'in
Martin now GO TO BED after consuming a few beers YOU DESERVE IT
JayDee
    • JOHN DOWD
« Reply #1227 on: January 12, 2019, 08:06:28 pm »
Martin,
Just a suggestion, have a sit down, with some Whiskey in a Large glass !!!!!!!!!.
You really deserve it !.
John.  :-)) :-)) :-)) :-))
http://www.john-dowd.
« Reply #1228 on: January 12, 2019, 08:11:04 pm »
I agree with that, and find someone to feed you peeled grapes  :} Thanks for everything you do Martin.
I assume when things are not as they should that you are doing something important to the forum, but like to mention it just in case it is a SPAMhawk doing evil things to your years of effort as well as ours.
« Reply #1229 on: January 12, 2019, 11:50:16 pm »
Now Martin......I am certainly not decrying you a plate of peeled grapes of a large Chevis Regal & ice  {-) .....however I don't quite understand why the backup is so arduous?
On this, my small Ultabook [up stairs], I do a Norton backup to a 2TB external drive [via USB2] once per week ......backup contains all data except Software and is ~~ 6.7MB .....[or only about 60% the size of your file]Norton only takes 8 minutes to overwrite this in backup format, or ~~12 minutes if I create a new file...& then 8 minutes again to overwrite it etc
If it was just the server box size imitation that caused the glitch? ...can you perform a local backup on your machine prior to a duplicate files being sent off to the server?....or are we actually linked to your machine live 24/7?
« Reply #1230 on: January 13, 2019, 02:32:22 am »
Hey sir Derek!
You don't download 'Mayhem', a whole website, direct from a Host server.
It takes hours to download such massive amount of LIVE data, so while you would be doing it, the Forum would be still be running & changing,
i.e. updating with new posts, new photos uploaded, SQL Db constantly updating, cache changes ....
So by the time I've finished downloading the backup, the data will have changed significantly, therefore the hosting software creates a 'snapshot' -
which is now 16Gb! .... you try downloading 16Gb and see how long that takes you, even with a fast connection!  :-))
"Anyway, it creates a 16Gb.Gz (compressed) file on the server which you then download ........."
« Reply #1231 on: January 13, 2019, 02:48:43 am »
OK....sorry :embarrassed: ........got it Martin............. your 16GB is about 2600 x my BU  :-X  ..........and it is downloaded, not transferred....... Derek
« Reply #1232 on: January 13, 2019, 03:17:25 am »
How you doing Derek?
« Reply #1233 on: January 13, 2019, 05:27:58 am »
Just getting the solar powered - battery backuped   Abbacus back on line  {-) Derek
Tug Fanatic
« Reply #1234 on: January 13, 2019, 07:53:07 am »
[/l][/font][/color]
About 1.5hrs but with downloads I often find the slowest element is the rate at which "they" are shoving the data into the pipe at the other end.
« Reply #1235 on: January 13, 2019, 08:01:51 am »
Never realised you were a ABBA fan Derek. Are you the Dancing Queen?  %)
swiftdoc
« Reply #1236 on: January 13, 2019, 08:46:00 am »
« Reply #1237 on: January 13, 2019, 09:28:10 am »
Well Colin...I fully admit to purchasing an audiophile quality mastered tape record album containing the track of the single Waterloo
It was an amazing coup by the Swedes to capture the World..as they did :-)) ...
Interestingly, according to the latest UK - EU Archive releases, one Colin Bishop was Member number 20173 of the ABBA Fan Club UK in 1983  O0
[PS...the lady who is now a recluse on an island ....I thought was very nice  :kiss: ]
« Reply #1238 on: January 13, 2019, 09:51:52 am »
Not guilty m'lud but I do confess to buying Mrs B the second Mamma Mia video for Christmas.
Anyway, I thought you would have been in bed by now...
« Reply #1239 on: February 16, 2019, 01:11:12 pm »
Just a quick question and not related to the above - it was related to another issue regarding sizing.
It happen recently, i don't know if it still happens, you write a length of text, then realise the you want to put the back half as a separate sentence, so you put a couple of returns in to get the back portion onto a separate line, then you return it to where it was because you moved it from the wrong spot and the text reduces to a smaller size.
Just tried it again in this post and it didn't do what happened earlier - so it must be my set up. sorry to have troubled you.
« Reply #1240 on: February 16, 2019, 01:20:11 pm »
Seems to be a bit random.
Sometimes it happens, sometimes
not
Sometimes after an emoticon?
« Reply #1241 on: February 16, 2019, 01:21:06 pm »
Not that time <*< <*< <*<
« Reply #1242 on: February 16, 2019, 02:05:43 pm »
As sombody suggested earlier, if you select the red A Toggle View on the second line (above the emoticons) before typing any text it often seems to be better.
grendel
« Reply #1243 on: February 16, 2019, 04:54:27 pm »
I seem to recall Martin used the naughty words filter to change the size 2 note to size 14 to solve the small text issue.
« Reply #1244 on: February 16, 2019, 06:32:05 pm »
    O0   ok2
« Reply #1245 on: February 17, 2019, 09:28:00 am »
I understand and saw that mentioned, the text went to less than 8 pt, had to increase it to 10 pt to be close to the correct size - again it may be my set up.
« Reply #1246 on: February 17, 2019, 09:34:27 am »
No Warspite it happens now and again
sometimes when you go back and modify I think Martin might have shares in specsavers %)
« Reply #1247 on: February 17, 2019, 03:06:41 pm »
 {-) {-)  If I spot it, I usually edit it out .... I think I'm becoming more OCD as i age......  {:-{
frogman3
« Reply #1248 on: February 21, 2019, 12:37:40 am »
Admin asked me to post 5 messages to test verification security.
5 - Martin, please delete.
Thanks Martin, 5 was the magic number.
« Reply #1249 on: June 10, 2019, 04:19:41 pm »
Page created in 0.042 seconds with 22 queries.
