Author Topic: receivers  (Read 2334 times)
martin brewster
receivers
« on: April 18, 2014, 09:02:52 pm »
hi can anybody help i have two high tech receivers three channel i have been told i can connect them together to make one six channel the channels i need to use are three, five and six. by the way this is 40mhz
Robert Davies
Re: receivers
« Reply #1 on: April 19, 2014, 12:13:29 am »
I've not heard of it being done sorry. That's not to say it can't be done.
I'm sure you've tried already, but being as you only need three channels, and on a mode 2 TX ch3 is throttle and 5 and 6 are either gear or flaps. Setup one of the three ch rx with a servo in each and see if they respond to your existing TX. Usually on a three ch system throttle is one, steering is two and aux is three
If you are still using your F14, it's a big plug and play bundle inside, so note where the ch plugs are now (they're all numbered in mine anyhow), and then you can try replugging the ch plugs till you get the ones you want plugged into the chs you want to make the three ch rx respond how you want.
Re: receivers
« Reply #2 on: April 19, 2014, 09:14:00 am »
There is really nothing to stop two receivers being in the same boat, they just each need their own transmitter.  Not a very elegant way of getting 6 control functions, but feasible.  Ish.
A model control receiver is not much like a normal radio which just feeds its output to a loudspeaker.  It takes an encoded signal which is carrying the information for the various output channels and distributes them, using hardwired logic circuits, to the required output slots.  In the case of a 3 channel set, the hardware is designed for 3 channels and that is what the hardware is designed to count up to.  Adding more requires a complete rebuild of the output stage, taking another and sort of grafting it on is not an option, since having the ability to count up to six is not the same as counting up to three twice.
AL 1
Re: receivers
« Reply #3 on: April 19, 2014, 10:48:27 am »
hi martin if you need a 6 channel hi-tec receiver give me a shout I think I have a couple cheers al
martin brewster
Re: receivers
« Reply #4 on: April 20, 2014, 11:29:47 am »
good advice thank you :-)) :-))
Page created in 0.184 seconds with 17 queries.
