January 20, 2021, 10:33:22 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem also on Facebook!
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Tugs and Towing
model flight motor
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: model flight motor (Read 1561 times)
clinker
Shipmate
Offline
Model Boat Mayhem is Great!
walderslade,kent
model flight motor
on:
April 24, 2014, 12:44:47 pm »
Hi, I have been given a "BARRACUDA" model flight motor, which is 3" dia.and31/2" long with a 8mm dia shaft. I can't find any information on this motor and am hoping someone can help me out here, I am hoping it will be o.k. to put in my tug Sea Trojen???
many thanks
clinker
hmsantrim
Full Mayhemer
Offline
U K
Re: model flight motor
Reply #1 on:
April 25, 2014, 02:16:56 pm »
Hi Clinker.
Its a motor from the 1980`s think it was black similar to a car fan motor. You would probably find the spec for it in an old mag advert for MFA stuff. Should be all right for the tug plenty of torque .
Frank.
Full Mayhemer
Offline
Meridian Line, Mouth of the Humber
Reply #2 on:
April 25, 2014, 02:37:25 pm »
MFA Barracuda
L 79mm x 76mm Dia 5/16" shaft,0.9Kg, !) pole Balanced armature
4A on load 12V 6A on load 24V
12V 4000 RPM 24V 8000RPM
Suitable 3 - 4 Ft boats.
Up Spirits Stand fast the Holy Ghost.
clinker
Shipmate
Offline
walderslade,kent
Reply #3 on:
April 25, 2014, 03:15:35 pm »
Many thank's for the information Frank and Ned, I will be using this motor in my 44" sea trojen eventually,lot's more to do yet .
nemesis
Full Mayhemer
Offline
North Shields. Northumberland
Reply #4 on:
April 25, 2014, 04:03:43 pm »
Hi, You can tell if it is a barracuda as it has a little pipe sticking up. I have used these motors for years. An excellent choice.
I ran my "Tyne Model" Northsider on a Barracuda, Geared 3 to 1 swinging a 5" prop, (prop shop). Nemesis
clinker
Shipmate
Offline
walderslade,kent
Reply #5 on:
May 02, 2014, 09:48:40 am »
Hi nemesis,I am intending to use this motor for my tug with a kort nozzle swinging a 90mm prop,so according to the different coment's that I've received it sound's like it will cope very well.
nemesis
Full Mayhemer
Offline
Reply #6 on:
May 02, 2014, 11:17:54 am »
Hi, Depending on the pitch of the prop it should be ok, check after running 10 minutes and see if the motor is getting warmish, fuse at 10 amp. I always drilled a little hole at the rear to oil the back bearing. Regards, nemesis.
Print
Pages: [
1
Go Up
« previous
next »
Tugs and Towing
model flight motor
