Pages: 1 2 [3] 4   Go Down
Author Topic: Fishing Trawler Propitious FR927  (Read 32400 times)
kees de mol
  • crazy about shipbuilding
Re: Fishing Trawler Propitious FR927
« Reply #50 on: August 13, 2014, 09:59:04 pm »
   Hi all,
Due to holidays and other cases, the work on the trawler for a while stood still, but that has now changed. Still several issues had to be made on the deck. I'm not sure what to call everything, but it is mainly rolls where the fishing lines come out and where the lines are led back. A railing with control for winch and three hatches and a winch made​​.
After this I must still make the railing and some small things and then the building is almost finished and it needs to be painted only.
In the pictures I show only the new stuff so you can see what's new.
The beginning of a winch
And then you get this
And here the new new dekfittings. I have no pictures of the building but trust me. It was not without any problems to find Proper shapes and sizes
And yes the chains are a bit too thick. For this, I am looking for a smaller one.
Groetjes, Kees
kees de mol
« Reply #51 on: August 14, 2014, 05:13:07 pm »
Hello people
Today continued with the factory of the bulwark. The legs must be made and aligned and that was lots of work. I have glued the feet  to the deck with a mould  (after I had measured out where to stand, of course) and then the horizontal pipes fitted.
Because Cyanoacrylaat-glue adheres poorly on brass I have every bonding later touched with a bit of epoxy glue.
It looks nice, and things are properly aligned.  The building is now ready apart from some minor things, and so we can start painting.
All fifteen ready
alles vast.
Sorry no further pictures here. Here is the epoxy I use
The almost ready-pictures
Groetjes, Kees
GAZOU
« Reply #52 on: August 14, 2014, 05:15:03 pm »
 O0
RAAArtyGunner
« Reply #53 on: August 16, 2014, 04:02:46 am »
Yup keep it static MDF and water do not like each other even glassed, painted and varnished. Don't ask!
Even the name MDF, Yuk
kees de mol
« Reply #54 on: August 16, 2014, 07:49:08 am »
Is Medium Density Fibreboard better? I think it's because I am a little bit younger than you people. Elderly people and new materials has always been a problem %%
Groetjes, Kees
« Reply #55 on: August 16, 2014, 12:20:05 pm »
I'm not elderly, just experienced!!  :kiss: Call it what you will keep MDF away from water whatever you use it for. Oh and wear a mask when cutting and sanding.
kees de mol
« Reply #56 on: August 16, 2014, 06:28:43 pm »
That's absolutly true. I use it for a static model but would never use it for an rc-model. For my static model model I have no problem with it. My father build his first model with mdf some 15 years ago and it still looks very good.
Hope I didnt offended you, I tried to make a joke.
Now on with the boats. I am currently painting the skipper who will be on the bridge
Kind Regards, Kees
Groetjes, Kees
« Reply #57 on: August 16, 2014, 09:00:19 pm »
No problem hence the smiley  :-))
kees de mol
« Reply #58 on: August 19, 2014, 07:28:04 pm »
Lately, I have been painting the second figure that will be placed on my ship.  It's Captain Job and he will soon be found on the bridge. I think it's successful and I've at least had fun painting.
Greetings and the next time more building and painting
Groetjes, Kees
kees de mol
« Reply #59 on: September 08, 2014, 09:41:49 pm »
At this moment I've come a little further with the boat. First I build some trawldoors. They are used on the trawlnet as a rudder to keep te net open.
After this I started the paintwork. The first staps are done but it is off coarse not ready yet. The weathering will take a lot of time and work. In this first stap I use the 'saltflake methode'.
Regards, Kees
Groetjes, Kees
kees de mol
« Reply #60 on: September 11, 2014, 06:17:19 pm »
I had a lot of fun weathering the ship these days. Maybe it's not everybody's taste but I like the result so far.
Groeten, Kees
Groetjes, Kees
mark w
  • "I stick my neck out for nobody"
« Reply #61 on: September 11, 2014, 06:36:42 pm »
Perfect  :-)) . A real working boat.
Mark
"If she can stand it, I can too, play it"
« Reply #62 on: September 11, 2014, 11:09:04 pm »
Have you considered Hi density foam? its much eaier to work than MDF?
http://www.easycomposites.co.uk/products/pattern-making/high-density-polyurethane-foam-block.aspx
kees de mol
« Reply #63 on: September 12, 2014, 08:23:47 am »
Thanks for the tip. I will consider it for my next build
Groetjes, Kees
kees de mol
« Reply #64 on: September 19, 2014, 03:14:19 pm »
The past few days I worked on the crane with powerblock. It's being used for hauling(?) the nets in.
Groeten, Kees
Groetjes, Kees
hama
« Reply #65 on: September 19, 2014, 04:11:32 pm »
You're obviously very talented and I'm looking forward to your future builds.
All the best!
Hama
GLEANER
  • Inactive
  • How does she sail with no wind in her sails?
« Reply #66 on: September 19, 2014, 05:00:57 pm »
Hi Kees de mol,
That weathering finish is fantastic, and very realistic, with dents and buckles too I notice. I am going to look up what the 'Salt flake method is'.         Superb ability.
kees de mol
« Reply #67 on: September 22, 2014, 04:55:25 pm »
The next job was the netroll. I started painting and weathering and after this I placed the net on the roll. Voor netting I use bathsponges wich have nice netting if you cut the string holding them together. I also painted and weathered the trawldoors wich are made from aluminium so no rust this time.
Groetjes, Kees
Rmay
« Reply #68 on: September 25, 2014, 02:23:02 pm »
Impressive work - the pictures look like the real boat.
mermod
« Reply #69 on: September 26, 2014, 05:08:00 am »
That's a real first class job of weathering  :-))
People who think they know everything are a great annoyance to those of us who do.
Isaac Asimov
RAAArtyGunner
« Reply #70 on: September 26, 2014, 09:53:09 am »
At this rate she will soon be on the slips getting a new paint job %) %)
steve mahoney
« Reply #71 on: September 30, 2014, 06:58:04 am »
A friend of mine ran a trawling company. He used to describe the fleet hull colour as 'sunset gold' – rust.
Steve
kees de mol
« Reply #72 on: October 02, 2014, 06:24:29 pm »
Hello,
No words but deeds, so for today more pictures than talking. I am busy with all kind of (paint)jobs and the ship is approaching its completion
Regards, Kees
Groetjes, Kees
lunganu
« Reply #73 on: October 07, 2014, 07:21:48 am »
Hi kees can you mail me the plans for this ship.i want to generate a parent in delftship but i have only few pictures and those do not help me. thanks.catalin.by the way your trawler looks great. i like the way you do to look as an old and used ship.
i am sane,the voices in my head said so.
kees de mol
« Reply #74 on: October 15, 2014, 05:23:51 pm »
En hier zijn de eindfoto's
Groetjes, Kees
Pages: 1 2 [3] 4   Go Up
