Been working hard on the najade today, hopefully she'll be ready for preliminary sea trials on Sunday.
First order of business was adding the panels on the back quarter of the superstructure. I've been using super glue and acceleration spray. This lets you use superglue as really tough filler. Much better for gap filling that messing about with miliput. The gaps between the panels and superstructure have been filled and sanded flat:
The next part was a much bigger job that it looks. I needed to replace the original scratched glass with a fresh set that had came with the boat. Unfortunately when I tried removing it it was completely stuck to the bottom of the removable top. I had to cut away some of the plastic at the bottom and take the glass away in one piece. Then I had to rebuild the top using plasticard as the previous owner had made a hash of cutting it out and had cut to much away so the glass didn't fit properly. This was further complicated by the fact I had to make it fit perfectly as I couldn't add any filer when the glass had been fitted.
Finally I blended the wing bit onto the superstructure using the superglue filler technique and then sanded using 240 grit paper so it's now super smooth!
Tomorrow I'll be cutting out the portholes and installing the crazy expensive ones I bought from Germany!
