Yes Joe,
The hull was squared off today to finish off the hull frames ready for the drilling of the prop shafts. I then found that the hull was not high enough, so tried to mark out the hanger deck upper and lower gallery decks, which would not fit with the correct space between each. I could rub the hull sides down to remove the opening and the port holes that are marked in the gel coat, and then redo the W/L lower down and then using those marking mark out the decks, but that will make the quarter deck that I cut out for the access for the rudder tiller too high and not aligned up with the other deck openings on the same level. So before I do any more work on the hull to that end I am looking into making my own hull from the ship lines and than get my own made. If not I will continue with what I have and make do.
