I am awaiting my new mancave-I.E a large shed-with it not arriving until the 15th May 90% of my modelling bits and bobs are in bags and in storage-so cannot get to anything. But, I managed to get this Tamiya 1/35 Chieftain tank-part built at my local Oxfam shop for the...steady people...shocking price of all of £1.99!
As pointed out with the airbrush, most paints, masking tape etc etc all boxed and away I was going to leave this...but I got itchy fingers and figured that as it was cheap and a part build it could have bits missing etc so just to go and have some fun.
So, what to do? If you have seen the Tank Overhaul and Tank restoration programs on TV then this what I had in mind. A 40 year old MK5 that has been left outside for the past 10 years awaiting its turn to be re-newed.
Right, with resources seriously down to a minimum it was scrimp time. I used: Red oxide spray, light grey primer, matt tan, matt olive drab, matt black, gloss white, paintbrush, white-spirit, cotton buds, rust pigments, Tamiya clear red for the rear lights and a sanding stick.
The model was cleaned and when dry a coat of red oxide added, once dry a salt mixture added all over and then when dry I added a top coat of light grey primer, once dry the salt was knocked off leaving the red oxide showing through in places. This was then sealed with matt varnish-this same process was applied to the upper and lower hull, turret and side skirts. I then painted the wheels, which was tricky as the previous owner had attached them, this was done on olive and tan matt paint with the matt black added for the rubber tyres. Once all dry, a very diluted mix of matt black was added using a cotton bud and then dabbed etc to give a dirty washed look. Once dry this was again sealed in matt varnish before rusting began, this was using-rail rust, new rust and old rust pigments.
This model is 90% finished with some highlights, clear to add on lenses and the board to finish off, but that will have to wait.
Si:)
