Author Topic: deans marine steam at the South West model show  (Read 2295 times)
Dean's Marine
    • Dean's Marine
« on: May 01, 2014, 03:37:21 pm »
Deans Marine will be attending the South West Model & Hobby Exhibition 3rd & 4th May
 and will have display models of the new models kits released in 2013-2014 plus
 the huge range of new items for marine modellers added to the range over the past
 12 months from shafts, props,couplings, fittings and accessories
 plus
DEANS MARINE STEAM PLANTS
 First production run of the new steam plants will be available at the South West model
show.
 Live steam from Deans Marine / Mamod.
 A new range of products for live Marine steam.
 Starting with a gas fired ceramic burner boiler unit, Refillable butane gas tank
Three type of engines in the range, a twin cylinder oscillator vertical inline engine, with fwd and reverse control,
a single cylinder slide valve engine, and a flat twin oscilator paddle steamer engine,
Gas tank, lubricator, and condenser units are all available to mix and match as you wish.
 Also available as a set consisting of a complete steam engine / boiler set up matched
 to a roller bearing prop shaft, hi torque marine coupling and a 4 blade brass propeller
all matched to the steam plant.
 Hope to se you at the show, and pdf detail sheet is attached to the thread.
 Deans Marine
