Author Topic: sanding sealer  (Read 2511 times)
spike
sanding sealer
« on: May 27, 2014, 04:27:23 pm »
hi do you rub between each coats please and how many coats please
spike
Re: sanding sealer
« Reply #1 on: May 27, 2014, 04:29:33 pm »
also how long between coats please
barriew
Re: sanding sealer
« Reply #2 on: June 01, 2014, 09:04:15 am »
Depends what your applying it to. If balsa it will raise the grain so yes sand lightly. It is probably a good idea to sand anyway. How many coats? - what are you trying to achieve and what are you sealing? Again, balsa will require quite  a few coats as it will soak up the sealer. If you are looking to fill the grain in ply, then again keep going until you get the surface you are looking for. In this case sand more heavily between coats so you are filling the grain without adding too much depth on the flat bits.
Barrie
