Author Topic: The long and the short of it?  (Read 4570 times)
U-33
  • K-157 Vepr. Akula-11
« on: May 31, 2014, 09:59:52 am »
My newly acquired Robbe F-16 has the optional short helical aerial fitted to it...I also have the long metal aerial. What's the disadvantages of the shorter aerial, chaps...loss of signal, I guess? The radio will be installed in a sub, by the way.
Re: The long and the short of it?
« Reply #1 on: May 31, 2014, 10:45:46 am »
There is a marginal loss of signal range.  noticeable, but not enough to worry about under normal circumstances.
Using in a sub however, I would do a little range testing before fitting to your pride and joy
U-33
« Reply #2 on: May 31, 2014, 10:48:35 am »
Cheers, E2V...I guessed as much. Think I'll refit the long metal aerial, just to be on the safe side...
roycv
« Reply #3 on: May 31, 2014, 10:55:52 am »
My last Fleet system had a short stubby aerial (40 Mhtz.) and I found it only had 20 odd feet range.  I replaced it with a telescopic one and range is out of sight now.
regards Roy
U-33
« Reply #4 on: May 31, 2014, 11:01:53 am »
Cheers Roy...metal one due to refitted after I've finished me cuppa.
U-33
« Reply #5 on: May 31, 2014, 02:59:14 pm »
Job done...funny, the FC-16 aerial seems to be shorter than the one on my old F-14. Anyone else noticed that?
inertia
« Reply #6 on: May 31, 2014, 03:15:06 pm »
At the risk of sounding vulgar, the important length is when it's extended.  :embarrassed:
Rest assured that the one you have is the one which came new with the Tx.
DM
U-33
« Reply #7 on: May 31, 2014, 03:16:40 pm »
Absolutely Boss...no length = problems.
U-33
« Reply #8 on: May 31, 2014, 03:18:43 pm »
Oh yes, I know it is...I have absolute faith in your good self, Boss.
(I've just noticed that the image has come out sideways...how strange?)
« Reply #9 on: May 31, 2014, 03:19:54 pm »
inertia
« Reply #10 on: May 31, 2014, 05:09:01 pm »
See what I meant?
Stupid boy.............
DM
Liverbudgie2
« Reply #11 on: May 31, 2014, 05:11:59 pm »
Never had problems with my rubber encased ones.
LB
« Reply #12 on: May 31, 2014, 05:39:00 pm »
See what I meant?
DM
Sorry.... had to be done  O0
Robert Davies
« Reply #13 on: May 31, 2014, 06:07:53 pm »
See what I meant?
DM
It sounds better from….
Subculture
    • Dive-in to Model submarines
« Reply #14 on: May 31, 2014, 07:03:40 pm »
I use the helical aerial on my FC16, never had any range problems, although I tend to keep the sub close by, otherwise you can't see squat. It's easy to change if you choose to.
U-33
« Reply #15 on: June 01, 2014, 12:17:05 pm »
On our club lake I often go out on long distance patrols...about fifty/sixty yards or so away from me (that's surfaced) but when running submerged I tend to stick close in. When I had the Neptune with the F-14 fitted with a helical aerial, I did notice at odd times that the failsafes would cut in when sailing at a distance, but with the metal aerial fitted, there were no such problems.
