April 20, 2024, 12:26:54 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 25, 26
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
GRP HULL DRILLING
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: GRP HULL DRILLING (Read 1461 times)
Dave Cook
Cookie
Full Mayhemer
Offline
Keep on Rockin
Lancashire
GRP HULL DRILLING
on:
June 04, 2014, 02:38:41 pm »
Hi All , As anyone got tips on drilling rudder holes and cutting prop shaft slots in a GRP hull without chipping the gell coat .
Cookie
Full Mayhemer
Offline
near Fleetwood
Re: GRP HULL DRILLING
Reply #1 on:
June 04, 2014, 02:45:26 pm »
depends upon the size of hole you want to drill, dave..........if it's an 8mm hole for a prop shaft.........mask off the area with a masking tape including over the point where you want to drill and drill with a 6mm bit, enlarging the hole to the required size with needle files, or garnet paper( the yellow green or brown hard stuff) rolled into a tight pencil shaped roll...leaving the masking tape on the hull whilst you sand the hole to the right size.............this will elliminate any shattering of the gell coat.
neil.
deadbeat
Full Mayhemer
Offline
Waterlooville
Reply #2 on:
June 04, 2014, 03:08:17 pm »
.....and drill from outside in!
Full Mayhemer
Offline
near Fleetwood
Reply #3 on:
June 04, 2014, 03:24:08 pm »
oh, yeh............forgot to say that, sorry.........goodun deadbeat......just to cover all bases.
neil.
Dave Cook
Cookie
Full Mayhemer
Offline
Keep on Rockin
Lancashire
Reply #4 on:
June 06, 2014, 07:23:57 am »
Thanks Lads i, I will give it a go
CyberBOB
Full Mayhemer
Offline
Model Boat Mayhem is Great!
canada
Reply #5 on:
June 15, 2014, 07:01:25 pm »
I have good success starting from the outside, hss bit, slowly in reverse. Once you have ground through the gelcoat, stop, put the drill in forward, and finish the hole. It doesn't work with forstenor, spade or brad point bits though.
Time Bandit
Full Mayhemer
Offline
Deizisau, Germany
Reply #6 on:
June 15, 2014, 08:05:39 pm »
I always use those conic grinding stones for drilling machines to enlarge the hole.
That works pretty perfect.
regards
Tobias
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
GRP HULL DRILLING
