Author Topic: Freelance Trawler style yacht build  (Read 5366 times)
CyberBOB
« on: June 18, 2014, 12:11:59 am »
Where to begin?
When I was about 11 years old, I was looking at building a new model boat.  I had a few, and the bug had bit me hard.  I noticed during a trip to the local plastic shop with my Dad sheets of HIPS, High Impact PolyStyrene (I believe the rest of the world calls this plasticard).  I figured that looked much easier to bend and finish than wood, so I parted with a significant portion of my allowance to by a sheet.  I decided to make a freelance model of a trawler style yacht, as I liked the lines – something about the good looks of a boat based on a working craft spoke to me.  I started in the traditional way, with a keel and frames, and covered it with styrene.  It bent so nicely, and glued together so well with the tubes of model cement I had kicking around from putting together kits.  Not sure what to use as a filler on this, I used a product called Marine Tex, an epoxy based filler used on full size boats.  I scribed some mahogany ply, and stained it for the transom.  I used more scribed and stained mahogany for the deck.  Styrene was used for the superstructure and bridge, with some blue cellophane for the wind dodger.  The hull was light weight and solid, but I ended up with some serious print through from the internal frames.  Yachts shouldn’t have the “starved dog” look of old, battered steel hull vessels.
I ended up building several boats almost entirely from styrene as a kid, and learned a few things on the way.
When I got older, cars and girls distracted me from model boating.  It wasn’t until I was married with children, and looking for a quiet hobby while my wife recovered from surgery that I took up model boats again.  I dug out my trawler.  The hull was still reasonably solid, but the decades in between didn’t do anything to improve the “starved dog” look.  The cabin was made from some really thin styrene, and had spent the time shoved in a cardboard box, so needless to say was in rough shape.
CyberBOB
Re: Freelance Trawler style yacht build
« Reply #1 on: June 18, 2014, 12:23:48 am »
I decided to rebuild the boat.  I disassembled the hull, and used the pieces as a template to make a template out of cardstock.  After adjusting the lines a little, I cut them out of some new styrene I had just purchased.  I believe the hull was made of .060”, and glued together with model cement.  Clamping pressure was a combination of masking tape and “stitch and glue”.  Stitch and Glue is a term used in the construction of plywood boats with no internal framing, and consists of a series of small holes drilled near the edge of mating sheets.  Copper wire/electrical ties are used then to pull the sheets together to hold the correct curves while the glue dried.  No internal frames were used, the hull is quite small, and a monocoque  style construction works well.  Once the glue was dried, I reinforced the seams on the inside with epoxy thickened with WEST System 404 High Strength additive.  The solvents in polyester resin can melt the styrene sheets, so when I need resin, I only use epoxy.  After building multiple hulls as a kid, this is my preferred method of making a small hull, as the reinforced corners add a lot of stability and strength.  If some minor plastic creep does occur, it has a tendency of concaving the sides and bottoms slightly, which doesn’t detract from the looks.
The outside was faired with more epoxy, this time thickened with WEST System 410 Light Weight additive added, as this sands very nicely.  The subdeck uses two sheets of .060” styrene laminated together, with the lower sheet fitting snugly inside of the hull, and the top sheet sitting on top.  The transom is made up of some mahogany strips I ripped on the table saw.  The mahogany is scrounged from a reception counter that Mrs. CyberBOB’s Grandfather worked at, and is about 90 years old, so has a deep, rich colour, and a tight grain pattern, making it ideal for scale planks.  No stain was added to this wood, it is finished with an oil based polyurethane used for hard wood floors.
CyberBOB
« Reply #2 on: June 18, 2014, 12:24:52 am »
The cabin was traced directly from the surviving port side of the original.  I had to redesign the front and boat deck of the cabin, as the original was too far gone.  I used .040” styrene for this, with the inside corners reinforced with thickened epoxy.
The bridge is the original bridge.  As it was constructed with I think .015” styrene, I added a second layer.  This thin stuff I have had kicking around for 30 years, and most of it is still good (outside sheets in the stack were yellowed and brittle, the rest of the stack was good).  I did add inner sides to the bridge, and a dash, as the original was just an empty shell.  Blue cellophane fits snugly between the bridge front and dash, were it will eventually be glued in place.
CyberBOB
« Reply #3 on: June 18, 2014, 12:27:15 am »
The deck is a piece of .060” styrene.  It was cut to fit, with the opening under the cabin cut into it.  I then added the lip the cabin fits over.  I scrounged up some teak from a broken Danish Modern chair that was on its way to the dump.  This was ripped into strips.  I cut some curved pieces for around the outside.  I then proceeded to plank the deck, using .015” styrene as spacer.  Teak was glued down with crazy glue.  I then used some seam deck compound to fill the gaps between the planks.  This is the stuff they use to caulk teak decks on full size boats.  Once dry, I sanded it down.  Bulwarks were cut and glued on.  I masked the teak, painted the bulwarks, and glued the rub strake on right at the bottom of the bulwark.  There is no shear or camber to the deck, I decided to keep it simple.  Once I have my running gear installed, the deck will get glued down to the sub deck.  I am thinking of using something like SikaFlex, which is a marine adhesive/caulking compound.  It grips tenaciously, however I should still be able to force a blade into it and slice it off should my boat ever need major repairs.  Most things should be able to be accessed through the deck opening under the cabin, but this is just a belt and suspenders approach.
CyberBOB
« Reply #4 on: June 18, 2014, 12:28:34 am »
The doors are made up from more of the mahogany strip wood I cut.  I built it like a full size raised panel door.  First, 3 strips were edge glued up.  I then cut to size, and beveled the edges.  More strip wood was used for rails and stiles, which were grooved with saw and file.  Rails had tenons carefully cut into the ends.
CyberBOB
« Reply #5 on: June 18, 2014, 12:29:36 am »
Window frames were next.  I cut some of the mahogany on a scroll saw my Dad set up for cutting strip wood (he’s a model railroader).  It has a fence, and if you are careful, it can be cut so thin you can almost see through it.  I then used my combination bench hook/shooting board to cut the strips to the correct length/angle.  The ends were then filed smooth.  I then laid out a piece of tape, sticky side up, and laid out my 4 pieces.  Then new strips were cut, but with the overlap going in the other direction, so when I laminated them together, half lap joints were created at the corners.  This made them quite strong for their size.
CyberBOB
« Reply #6 on: June 18, 2014, 12:30:28 am »
I started with the hub of the propeller.  A chunk of brass rod was drilled on the drill press, and tapped out.  A section of threaded rod was then screwed and loctited into the hole.  This was then turned on the lathe, to achieve the correct shape, and true it up so the hole was in the exact center of the hub.  Blades were cut out of brass, and bent slightly.  I soldered the blades onto the hub, and started filing to get the right shape.  Propellor still needs a little more work, sharpening and statically balancing.
CyberBOB
« Reply #7 on: June 18, 2014, 12:30:50 am »
 A plough anchor was made, but after looking at the Delta Fast Set by gribeauval, and CQR made by bluebird, I’ve been inspired to make a new one (thanks guys)!
original print size enlarged, except this one
« Reply #8 on: June 18, 2014, 11:31:14 am »
Super thread Bob.   :-))
Could I ask that you increase the print size please as it's difficult to read.   :}
ken
now modified
CyberBOB
« Reply #9 on: June 18, 2014, 03:45:23 pm »
Sorry about that Kenny.  I typed it in Word and cut and pasted it into posts, forgot to change font size.  Doesn't look like I can edit it anymore.
« Reply #10 on: June 18, 2014, 08:54:37 pm »
Don't apologise. It's no problem.  You can only alter your posts for only 20 mins after posting (if it happens again).  Rather than using  Word  it might be best to type directly into here.
In the meantime, I will alter your size print to make it larger for everyone to read.
ken
CyberBOB
« Reply #11 on: June 18, 2014, 09:10:22 pm »
Normally I do on Forums, but it took a while to organize my thoughts, so used Word.
Thanks for adjusting the font for me.
CyberBOB
« Reply #12 on: June 20, 2014, 07:20:11 am »
I've almost finished the rudder.  A little more work with some fine emery cloth and it should be good.
I started by cutting a piece of brass shim stock the height I wanted, and just over twice the length.  I bent the shim stock around the brass shaft that will become my rudder post.  The whole thing was wiped down, and mating surface cleaned with fine emery cloth.  The shaft was tinned a little higher than the height of the rudder, and inserted back into the bent brass.  The trailing edge was soldered shut, and the sides heated up where the shaft passes through to solder the rudder to the shaft.  The top and bottom were filed flat.
I cut two pieces of shim stock to the approximate size and shape of the cross section.  These will become the top and bottom.  The top was drilled to slide down the shaft and mate up with the top of the rudder.
The hardest part of brass work (to me, anyway) is coming up with creative ways of clamping parts together while soldering, especially if you are soldering multiple parts on at different times.  I clamped the top and bottom on with a C clamp backed with wood, to prevent me from soldering my rudder to the clamp.  The trailing edge was held together with two clothes pegs.
Excess solder and overhangs were filed off, and the trailing edge was flattened slightly.  Some fine emery cloth was used to shine things up a bit.
CyberBOB
« Reply #13 on: June 20, 2014, 07:29:14 am »
The top is the side view of the rudder, the middle is the propellor that I made, and the bottom is the propellor from the original boat.  The original propellor is included for scale.  It is a 30mm plastic prop that has seen better days (30 years bouncing around in a cardboard box).
« Reply #14 on: June 20, 2014, 07:44:18 am »
Hullo Bob........heat sinks ....can assist  :o
I use 4 pieces of 3/8"square HSS blanks in a 3"machine vice.......these blanks do not mark the surface of the component being soldered
Wet paper tissue is also a great heat retardant way of minimising heat transfer to a close fitting pre soldered joint
The image below confirms 3 joins in reasonably close proximity ....the tube size is 5/32" OD & the bolts are M2
Full sized pipework practice or procedures applied to our miniature work is also a useful consideration :-))  Derek
Honorary Secretary
CyberBOB
« Reply #15 on: June 20, 2014, 08:13:01 am »
Thank you Derek.  I did try the damp tissue trick on a similar rudder I made for my nephew, but the problem was keeping the trailing edge cool enough not to spring, yet getting the top and bottom hot enough for the solder to flow.  The C clamps and clothes pins did the trick.  I'll have to remember the HSS blanks trick, I think my Dad might have a bunch of them stashed behind his lathe.  :-))
CyberBOB
« Reply #16 on: June 24, 2014, 06:16:42 am »
I wasn't happy with the first anchor I made.  Flukes were on the wrong angle, and the flat spot on top of the flukes bothered me.  I initially wasn't too worried about it as I figured it would be installed on the pulpit, and you wouldn't really see it.  But I saw some very nice scratch built anchors on this site, and decided to change it.
Original anchor:
CyberBOB
« Reply #17 on: June 24, 2014, 06:17:45 am »
Rebuilt anchor:
CyberBOB
« Reply #18 on: June 24, 2014, 06:20:28 am »
I also started working on the chain locker and pulpit.  They are temporarily set in place for taking the picture.
CyberBOB
« Reply #19 on: June 24, 2014, 06:22:13 am »
This shows how the anchor will be stored.
« Reply #20 on: June 24, 2014, 09:02:35 am »
I like the Anchor :-))
Would the bowsprit type mounting not have some sort
of metal protection to stop the chain wearing it away?
Also the slot needs to be wide enough to let the shackle
between chain and anchor pass through.
CyberBOB
« Reply #21 on: June 24, 2014, 07:33:02 pm »
Hi Ned,
Inspiration for remaking the anchor goes to this thread:
http://www.modelboatmayhem.co.uk/forum/index.php/topic,12211.msg115655.html#msg115655
The anchor platform is not complete yet.  I have some mylar tape to use for the protection.  I am just sealing the wood with some poly first.  I will then clearcoat the platform to keep the tape from peeling.  A roller will be added to the slot.  I designed the slot to fit the chain and shackle, but after reding your post, I decided to double check.  It still fits!
« Reply #22 on: June 24, 2014, 07:45:46 pm »
Hi Bob,
Sounds a good system  :-))
The photo makes the anchor stock look
as if it is a close fit.
You have it all under control .
CyberBOB
« Reply #23 on: June 24, 2014, 07:56:42 pm »
The gap isn't huge, but it is a small shackle and chain.
I'll need to make a tiny windlass as well.  I am really enjoying the scratchbuilding of all these little bits.
The forum is amazing.  Seems anytime I am making something, the search function bring up a post or thread, which gives me some ideas I haven't even considered.  A wealth of knowledge on here.
CyberBOB
« Reply #24 on: July 05, 2014, 10:32:41 pm »
A quick update while waiting for paint to dry.
After making the anchor platform, I started on the bow roller.  I started by snipping the end off of one of the tubes that comes with a can of compressed air.  I then wrapped two pieces of copper around the tube.
