Author Topic: Painting glassfibre hull ready for use in salt water  (Read 1288 times)
type82
  • Landing Craft Mad
« on: June 21, 2014, 01:00:39 PM »
Our lake here in Portsmouth is salt water what the best way to prime and paint a hull for this lake
Obsessed with Landing Craft and Shermans
Re: Painting glassfibre hull ready for use in salt water
« Reply #1 on: June 21, 2014, 04:12:13 PM »
Why not ask the guys who sail there all year round.
They will tell you what they use :o
« Reply #2 on: June 23, 2014, 08:26:31 AM »
no different from any other water.........I sail solely on salt water at Fleetwood.............with all my grp hulls.
etching primer..............then filler primer ..............then normal primer, white or grey depending on top colour............and them my top gloss coats..............all spray paints from Halfords..............never had any problems.
cdsc123
« Reply #3 on: June 23, 2014, 08:33:39 AM »
run it up in the bath afterwards otherwise the shafts etc will corrode this also gets rid of the salt crystals which could leave a mark.  :-))
deadbeat
« Reply #4 on: June 23, 2014, 02:48:44 PM »
Another thought is: after your run on the pond and you have your boat back on the stand run the motors in reverse for a few seconds to remove any water that crept in the shaft tubes. Take a bottle of tap water with you and wash down the hull, props, rudders etc. Then lube the shafts. Most prop shafts these days are stainless steel so rust won't be a problem although salt build up may. Take care of the rudder shafts as well as they may not be stainless, lube them as well.
