Pages: 1 2 [3]   Go Down
Author Topic: ANOTHER ROBBE PT 15 BUILD  (Read 34040 times)
rp6705
Re: Another Robbe PT 15 Build
« Reply #50 on: September 03, 2007, 03:43:53 pm »
Thanks for that O0
J.beazley
  • The building never ends
« Reply #51 on: September 03, 2007, 04:54:34 pm »
looking good as always Richard  O0
Jay
« Reply #52 on: September 06, 2007, 11:34:58 am »
Thanks Jay O0
6705russell
Re: ANOTHER ROBBE PT 15 BUILD
« Reply #53 on: September 19, 2007, 10:35:04 am »
Richard,
What motor/battery/speed controller set-up do you have in your PT?
Russ
« Reply #54 on: September 19, 2007, 11:31:31 am »
Hi Russ
Mtronics Vision 600 motor
Overlander 50amp speed controller 50amp Forwards & Reverse. (20Amp reverse) with a 20 amp fuse [No set up just plug in and go]
9.6v 4300mah racing pack battery from http://www.component-shop.co.uk/html/batteries.html  [very good price]
Goes like the clappers. Only use half throttle to plane at scale speed.
Get about 30mins continuous running but dont often do that as motor gets a little warm, so have a few breaks. O0
6705russell
« Reply #55 on: September 19, 2007, 01:46:54 pm »
Thanks,, i am running mine on a 12volt but not sending her out at full throttle otherwise shes not doing scale speed
Russ
« Reply #56 on: September 28, 2007, 05:09:09 pm »
Have just changed the motor to a Deans Marine Kestrel 5, 5 pole motor running on 9.6 V as the Mtronics Vision 600 was too powerful and was running too hot and noisy.
The Kestrel has slightly less power but it only gets warm and you cant hear it running. Still gets on the plane alright and doesn't need suppressing.
J.beazley
« Reply #57 on: September 28, 2007, 05:42:05 pm »
In other words Richard its less of a handful on the water then  O0 ;D
Jay
« Reply #58 on: September 28, 2007, 05:47:02 pm »
Jay
Trouble was Jay, that with the vision 600 it wasn't in the water much, it was airborne and hot.
J.beazley
« Reply #59 on: September 28, 2007, 08:33:24 pm »
Have you thought of water cooling the motor (should look at the build thread more closely)
Then again with a slower motor it will last longer on the water  O0
Jay
« Reply #60 on: September 28, 2007, 08:47:10 pm »
Jay
Got a water cooling coil on the bench Jay. I am going to use it with the vision600 motor in my 1970's cabin cruiser.
J.beazley
« Reply #61 on: September 28, 2007, 10:39:08 pm »
I see the bigger picture now  ;D O0
good motor for the cruiser and im sure it will have her wave jumping like a P1 powerboat :o
Jay
Pages: 1 2 [3]   Go Up
Page created in 0.059 seconds with 21 queries.
