Author Topic: help with steam engine  (Read 5852 times)
markymar93
« on: June 29, 2014, 11:36:53 pm »
Hi
I don't know if anyone can help me.  I am a longtime aeroplane modeller and recently into boats.  I have just about finished my first boat and I have just bought my next project, which is a steam tug.  I bought the boat part built and it needs a full strip down and rebuild.  As part of this, the boat did come with a home build steam engine.  I have to confess that I am a little out of my depth with the engine and wondered if there is anyone who can help me work it out?
Many thanks
Mad_Mike
  • Lincolnshire
Re: help with steam engine
« Reply #1 on: June 29, 2014, 11:48:19 pm »
got any pics of this engine :o
markymar93
« Reply #2 on: June 29, 2014, 11:53:18 pm »
Hi
I have attached a pic of the boat which also has the engine.  I will try and attach a few more pics of the engine.  I am also trying to identify the boat, as I will be rebuilding the boat as well.
Many thanks
Mad_Mike
  • Lincolnshire
« Reply #3 on: June 30, 2014, 12:15:10 am »
do you know anything about the boiler? what it made from, what its soldered with and if its been hydraulic tested?
markymar93
« Reply #4 on: June 30, 2014, 06:15:00 pm »
Hi
There are actually pics of the engine under the general boat section.  I will see if I can post them on this page tonight as well.
Many thanks
hammer
« Reply #5 on: June 30, 2014, 09:15:45 pm »
Engine a V twin oscillator, the boiler very interesting!!!! Looking out for more pics.
markymar93
« Reply #6 on: June 30, 2014, 10:46:34 pm »
I will attach a few pics in the next few messages
markymar93
« Reply #7 on: June 30, 2014, 10:47:32 pm »
next pic
markymar93
« Reply #8 on: June 30, 2014, 10:48:07 pm »
next pic
markymar93
« Reply #9 on: June 30, 2014, 10:48:51 pm »
next pic
markymar93
« Reply #10 on: June 30, 2014, 10:49:26 pm »
next pic
markymar93
« Reply #11 on: June 30, 2014, 10:50:00 pm »
final pic
Jerry C
« Reply #12 on: July 01, 2014, 08:45:33 am »
A puzzle. Is this a V-twin piston valved double actor with a gear driven feed pump between the cylinders? It's not a wobbler, but why are the cylinders different? Is it a compound? Is there a controller, or does it just let rip?
            The boiler appears to be a twin drum water tube boiler but where does the fire go?
        The hull looks like a planing type and the flywheel has a chord groove around it.   Maybe some sort of high speed steam launch.  Someone knows.
Still puzzled.
Jerry.
markymar93
« Reply #13 on: July 01, 2014, 09:36:21 am »
I am hoping someone can help me.  I would love someone to give me a hand to see if the engine can run.  Although, for the size of boat, it will need some sort of throttle and reverse control.  I cannot see how it can be controlled on the engine.
« Reply #14 on: July 01, 2014, 10:20:57 am »
The issue of posting two questions about the same issue on different threads......... :-)
____________________________________________________________________________________________________
That's also opened the door for a whole load of different engine parts  :o
The STDB cylinder has eight sets of round head screws & nuts top & bottom securing the caps to the barrel flanges
The PORT cylinder has what appear to be six long cheese head screws from the top of the top cap down through the cylinder barrel to the bottom cap & terminated with nuts.......
I wonder which was the original version?...........Derek
geoff p
    • Purple Tiger
« Reply #15 on: July 01, 2014, 01:54:57 pm »
Like Jerry, I read it as being a compound.
The exhaust from the Right-hand cylinder is re-heated before entering the Left-hand cylinder, and its larger-bore possibly doesn't leave enough room for screws-and-nuts.
It looks as though the single valve atop the boiler passes steam to (probably) a drier tube or even that coil in the "funnel", hence the string-insulation on the main steam-line to the engine.
Geoff,
Thailand
hammer
« Reply #16 on: July 01, 2014, 09:43:18 pm »
I was way of the mark should have waited for the close-ups.
markymar93
« Reply #17 on: July 02, 2014, 11:03:52 pm »
I do appreciate all the pointers people are giving.
thanks mark
markymar93
« Reply #18 on: July 03, 2014, 06:07:09 pm »
Hi
I just wanted to thank everyone for there help.  I have just bought a Robbe Odin and am thinking I may sell the steam boat as I think the Odin will take some time to build lol.
thanks
Geoff
« Reply #19 on: July 22, 2014, 02:17:15 pm »
As a thought I wounder if the boiler is "flash steam" given the multiple tubes (continuious tube) visible in the boiler and the engine driven water pump?
If it's flash steam I think you don't require a pressure test certificate.
I suspect one of the pistons has been replaced hence the different cylinder design?
Such being the case it may originally have come out of a flash steam hydro?
Enjoy
Geoff
Page created in 0.381 seconds with 21 queries.
