Is anybody reading this???
Progress today was exceptional
I sanded the original short spray rails off, they were doing nothing, and far too much water was hitting the deck, compounding the water leaks. Using square profile 2mm plastic strip I fitted full length spray rails front to back hoping that this would help with the amount of water hitting the boat. On test today, in slightly choppy water, I am really happy to report it worked, the deck is now almost bone dry, after 20 mins throwing it all over the place.
It also greatly minimised the torque roll, although right hand turns at speed against the direction of both props need to be handled with care to prevent the boat digging in and trying to go straight on. Counter rotating props will sort this.
The rear covers are in the process of being modified to be water tight, and the first version which was just taped on worked, the inside of the hull was dry, with the signal problem sorted, I can now finally move on from the mechanicals to the cosmetics and at last think about starting the paint and fittings
