Hello very new to 2.4 gig stuff so I will ask a few daft questions to those who probably know about this stuff.
I run large fast ic powerboats all over the place, rivers sea lakes infact anywhere that's wet enough to run them.
Now recently I have got hold of what I think is an amazing little 4 channel tranny and rx with 4 channels very cheap BUT
not heard much about this brand at all.
the make is ART -TECH E-FLY 2.4 GHZ DSM 4 channel transmitter with an e-fly er62 6ch rx.
I have seen a few on you tube but mainlky by people promoting the stuff so they would obviously say its great and best stuff around, Yeah right !!!
Firstly I thought the Ariel wire on the receiver had been cut off as its only about an inch long, turns out this is the correct length
this I think is a bit weird and might be a problem for the type of waters I run in as often I can even see the boats due to waves and wash
from full size powerboats on the sea for a split second or two, but at 50mph a second can be a long way !!!.
so what do I do about an Ariel (antenna if your a yank), as in where is best place to mount the receiver as ive heard some people say it needs to be up as high as possible and definitely above water line
can I extend the Ariel or do I need to mount the receiver up and out of the radio box, completely defeating the waterproof box its normally housed in ?
and what sort of distance can this set give on water ?
on land ive tried it and have not had any problems over a 1/8th of a mile but this was direct line of sight ?
any advice on this type of stuff would be good.
phill
