Author Topic: Futaba FF7 conversion to 2.4 ghz ?  (Read 4870 times)
phillnjack2
« on: July 22, 2014, 08:25:45 pm »
I have heard that simply by buying a new module that just replaces the one on the back of my old futaba FF7 can give me a full 2.4ghz transmitter ?
I would be buying the receiver to go with the module at same time that is compatible but wondered if there is any problems in doing such a thing.
This would allow me to have my well proven and trusty radio for marine use without getting any interference.
and would this give me a decent range ? if so how much  on water ?
or is a new cheap plastic 2.4ghz set just as good as my old futaba ?
phill
w3bby
Re: Futaba FF7 conversion to 2.4 ghz ?
« Reply #1 on: July 23, 2014, 09:29:45 am »
You've asked this before....
Modern radios come with failsafe functions for loss of signal, low battery etc. Use of these can prevent a runaway boat but you will need to be prepared to retrieve a dead boat from the water.
phillnjack2
« Reply #2 on: July 23, 2014, 01:38:10 pm »
yes I did ask this a long time ago, and forgot the answers to it. (that's why I asked again !!!! :P )
I fit my own fail safes to my boats and never worried about a dead boat in the water as I am in my speedboat with it 99% of the time.
I have seen some pretty cheap modules from a few different makers, and wondered what are good and what are bad.
I would buy a genuine futaba  if I find a cheap one used. Futaba prices are far too much for stuff they don't even make.
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #3 on: July 23, 2014, 02:08:24 pm »
The FF7 does not have a replaceable module, so you will need a hack module. I don't think Futaba make any hack modules.
I converted a FF7 to 2.4ghz, pictures at the bottom of this thread
http://www.modelboatmayhem.co.uk/forum/index.php/topic,24085.0.html
Check out the cost of receivers as well, they are normally specific to which 2.4GHz system you are using.
Subculture
    • Dive-in to Model submarines
« Reply #4 on: July 23, 2014, 02:13:26 pm »
A few years ago, it was worth doing. Now, unless you have a radio which you're really fond of and/or has some unique capabilities you wish to retain I wouldn't bother.
I would go with Spektrum/Orange based gear. It's the closest you can get to a standard with 2.4ghz, and there is a huge range of receivers at very competitive prices.
phillnjack2
« Reply #5 on: July 23, 2014, 02:39:21 pm »
sorry mankster
 but the pics you refer to are not of a field force 7 like mine.
I think your mistaking what a real FF7 is ?
mine does have a plug in module on the back
here is the original FF7 from futaba, and no the colour is not wrong, its a metal look bronze finnish.
Mankster
  • Wheelerdealer
« Reply #6 on: July 23, 2014, 04:32:34 pm »
Ops, got carried away... :embarrassed:
tsenecal
« Reply #7 on: July 27, 2014, 05:48:00 pm »
phillnjack2,
i have several of the FF7's bigger brother the 9cap , and i have owned the 7uap, and 8uap (the US name for the FF7, and what i assume would be the FF8 )
all use the same module for the RF deck.
I have purchased and highly recommend the Assan module and receivers.  i have several (almost a dozen) of the Assan 6 and 7 channel receivers.  one nice thing about them is that they have their own built in failsafe setup.
they can be found at most chinese websites including HobbyKing.
