Author Topic: which motor, prop combination ?  (Read 5421 times)
freelancer
« on: May 20, 2006, 03:53:22 pm »
Greetings to all modellers
I am building a 51 inch frigate and ask that all modellers with experience building this scale ( 1/96 ) advise me on which motor / prop / battery combination will likely result in the most realistic speed. I would prefer to install a system which will provide more power than required just to make sure it will reach realistic speeds. I will only install a single shaft, single motor,
I am looking for a battery, motor combination that will provide 30-40 minutes of running time. I anticipate the sailing weight to be less than 10 lbs.
TIA
Re: which motor, prop combination ?
« Reply #1 on: May 20, 2006, 07:01:21 pm »
A 550 motor and a G. Sitek scale prop, or prop-shop prop, simon will tell you the best one.
2 x 7.2 0r 8.4 volt 3300 Metal Nickel Hydride batteries or a couple of 2400 Nicads.
The motor should pull about 5 - 6 amps in usual running, but higher when manouvering.
You could also run a 777 motor from Model Motors Direct
« Reply #2 on: May 20, 2006, 09:24:44 pm »
Anyone know anything about or used the "777" motors?
Mayhem
Pirate
« Reply #3 on: May 21, 2006, 07:56:07 am »
Hi, my younger son uses a 777 direct onto a 50mm prop shop prop through a kort nossel on his 27 inch tug, it has more!!!!than enough speed, runs cool from 12volt supply for about 1 and half hours. Will say that not all speed controlers like 7 pole motors and lower performance can be a bit iffy if not dangerous to the esc , do be carefull. Another of our club members runs a large 4o inch fishing vessel via 777 on 6 volts at a very good endurance rate and scale speed. I'm sure a word with Allistair will sort things out with you. Oh the other point is the 777 has a very short stub shaft with a brass spline affixed with a grub screw.not a problem just a solution to find!!!
Pirate
Model Boats Website
  • www.model-boats.com
  • Model Boats Website
« Reply #4 on: May 21, 2006, 09:20:49 am »
I did purchase a 777 motor however I found them to be very heavy and it seemed to be slower than the 540 motor I had in previously.
If your after more speed, I would recommend the Graupner motors. ;)
freelancer
« Reply #5 on: May 21, 2006, 03:00:59 pm »
Greetings fellow modellers
Thank you for the advice, will certainly look into some of the options mentioned. There seems to be endless variations available however I am now of the opinion the ESC is a critical part of the system, some work better than others-expensice research however LOL
I like the idea of a heavy torque motor rather than high RPM as I wish to have a long cruise rather than a fast one. First time I have heard of the 777 motor, may be worth some study.
Thanks to all for the replies.
Cheers from my dockyard
« Reply #6 on: May 21, 2006, 04:45:04 pm »
If you go for a slower, more torquey motor you will have to up the size of your prop to compensate.
I have used a 4 blade prop-shop prop on a motor giving about 5000 rpm on a 5 foot Battle class, she did go ok.
