Author Topic: its my STAR.. the pleasure cruiser...  (Read 10782 times)
Krishna
  • aqua plannerrrr....................
« on: August 09, 2014, 11:58:55 am »
after lots of requests from my friends just on this simple boat, that can make in to anything.. so simple that is needed only 8 parts.. simple to cut and glue.. well balanced.. starting with a pleasure cruiser.. so simple.. 100% foam board, as the deck sheet and bulk heads are  4 mm and all other are 3 mm...
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
Krishna
Re: its my STAR.. the pleasure cruiser...
« Reply #1 on: August 09, 2014, 12:01:14 pm »
so simple to make that can finish her in an hour...
Krishna
« Reply #2 on: August 09, 2014, 12:04:17 pm »
in action.. i calls her as Lake Cat...
https://www.youtube.com/watch?v=g1ubEd5Nyxs
Nordsee
« Reply #3 on: August 09, 2014, 02:06:35 pm »
Very nice! Just the thing for a School Group to build. You say Foam board, what is that exactly? Also could you scan the sheet with the bits on and post it? I think lots of others would like to make one!Quite a Commercial opportunity there I think!
Krishna
« Reply #4 on: August 09, 2014, 04:58:19 pm »
sure Nordsee.. its so easy.. and its so inexpensive.. i will scan the drawing and share you.. while i am making lots of variations with super structures, from torpedo boat to open hull boat.. i9ts so balanced.. and just can go with a toy motor..
the foam board i uses here is based on P V C, the technical name is styroflex, came as sheets of 8X4 feet, in various thickness.. here i used 4 mm for deck sheets and bulk heads while 3 mm for sides and bottom.. this makes the craft so rigid.. and so lite in weight.. usually this sheets are used to make sign boards, name plates, and thicker sheets for making false ceiling and room partitions.. can also buy in various density and colours.. the two sides will be so smooth, so we can use the craft even without painting..
setsunakaede
« Reply #5 on: September 12, 2014, 03:20:32 pm »
Hi Krishna,
Can you please also share the scans with me? It looks like a perfect model to build with my daughters as one of their first ships...
Also, what is the vessel in the back? Looks good too.
Krishna
« Reply #6 on: September 12, 2014, 06:02:41 pm »
uyyo.. please do not angry on me.. the scanned A3 papers are still in computer center.. i just kept it there because of heavy rain here.. its not good to fold to take with me on my scooter.. i will collect it next day and shares you.. its a perfect size, and well balanced, easy to make within an hour, by this time i made 12 of them in various segments including a torpedo boat.. still 3 more hulls are in free..
the primed super structure is belongs to Emma Maersk, and the 4 feet craft is for the Naval institution, is an OPV.. have a lots to do, now working on engine sound unit, and helicopter..
setsunakaede
« Reply #7 on: September 12, 2014, 07:57:34 pm »
Wow, those variations look good Krishna. I look forward to the scans, no rush - my girls are not at an age yet that they can sit down patiently enough to build their own boat, I am just collecting plans for when that day comes  ok2
I hope you'll share that OPV vessel as well, it looks really good as it stands on the photo!
Krishna
« Reply #8 on: September 17, 2014, 07:25:29 pm »
tied up in some static models.. will share plan in short time.. thank you..
hobbymartin
« Reply #9 on: February 07, 2015, 10:08:15 am »
Very cool.
 :-)) How long did you need to speed?
Krishna
« Reply #10 on: February 08, 2015, 04:55:58 am »
uyyoo.. sorry.. just moment..
Krishna
« Reply #11 on: March 15, 2015, 05:12:31 am »
Friends.. sorry for the delay.. no A3 scanners near me.. so just scanned as A4, and joined.. so the length of the boat hull is 15.5 inches, while measuring through the center line of the deck sheet..
the printout are in A3 papers..
the bulkheads are numbered from nose to back, as 1,2 and transom.. use 4 mm foam, or balsa sheet for deck, transom and bulkheads, while 3 mm for sides and bottom..
Krishna
« Reply #12 on: March 15, 2015, 05:14:31 am »
please trim out 3 mm each side of the transom, to fix the side sheets nicely with the transom..
mariopozzi
« Reply #13 on: April 07, 2015, 11:46:56 am »
do you have a scan of the "cabin-cruiser" version's top part?
 ok2
Krishna
« Reply #14 on: April 07, 2015, 12:48:03 pm »
sure..
mariopozzi
« Reply #15 on: April 07, 2015, 01:29:24 pm »
... and will you share this with us so we can copy your boat  O0 ?
ciao!
mario
Krishna
« Reply #16 on: April 14, 2015, 07:12:29 am »
bit of time.. sorry for the delay..
setsunakaede
« Reply #17 on: April 29, 2015, 01:17:41 pm »
Hi Krishna,
Thanks for sharing the plans for STAR, I think I will build one some day with the little girl. And I concur with Mario's question; the canopy plans for the cabin cruiser would be very nice indeed!
Krishna
« Reply #18 on: May 01, 2015, 05:51:15 am »
Friends.. once again so sorry for the delay.. no scanners around me.. will share you within a day.. have to go nearest town.. while, we can make any boat with this hull.. lobster boat.. little trawler.. waiting to add.. sorry for the delay once again..
Krishna
« Reply #19 on: June 13, 2015, 07:27:28 am »
another simple version on same hull..
setsunakaede
« Reply #20 on: June 13, 2015, 10:12:20 am »
That is a good looking boat once again, Krishna! Well done!
Krishna
« Reply #21 on: June 13, 2015, 10:20:44 am »
yes.. beautiful.. thank you Setsunakaede..
Krishna
« Reply #22 on: June 21, 2015, 07:15:05 am »
another one.. is Rescue Dinghie.. same hull but with a little extra work with foam tube.. so easy.. so responsive..
Krishna
Unsinkable 2
« Reply #24 on: June 21, 2015, 07:36:18 am »
What a nice little boat :}
You are very busy, how many boats do you have? I think that I will make one of these if I can find the styrofoam in my local DIY shop. Looks fun.    U2
Page created in 0.036 seconds with 21 queries.
