Author Topic: Strength of HSS Drill bits  (Read 4248 times)
« on: August 13, 2014, 04:18:05 am »
Guys.......the following image is of a 3.0 mm diameter twist drill  O0....only used once ......to drill a 3.0 diameter hole in an automotive sheet metal panel 0.25 mm thick
It is stamped 3   followed by the letters HSS  {-)
Well...... >:-o it may have been a Grade of HSS at one stage ....... :P ...but I am not sure about the quality of the heat treatment  <*< ......Derek
Bob K
  • Bob K
Re: Strength of Metals?
« Reply #1 on: August 13, 2014, 07:17:28 am »
The term chocolate fire guard (as in 'as much use as a ...') comes to mind.
david48
« Reply #2 on: August 13, 2014, 10:10:38 am »
I bought a large brill set from a old and established tool retailer in the uk .drill size from 1mm to 13mm and all half sizes in between .for wood metal and stone . Every one I have used has done just that . It was one of them deals that was too good to miss ,cost £18 just goes to show you get what you pay for .The only thing thy are good for is for formers for wire bending and making rings .
David
grendel
« Reply #3 on: August 13, 2014, 12:31:22 pm »
well it certainly looks like it twisted, you cant get them under the description.
Grendel
« Reply #4 on: August 13, 2014, 04:29:40 pm »
It's obviously for drilling around corners  %%
Mad Scientist
« Reply #5 on: August 13, 2014, 09:43:37 pm »
Gosh, when I saw that drill bit, the phrase 'Chinese amps' was the first thought I had. Wonder why?
Tom
AlexC
« Reply #6 on: August 16, 2014, 09:59:46 pm »
It's got LH spirals as well... not much use for right handed holes :embarrassed: :} %)
I'm sure you can untwist it the right way Derek.
Keep happy.
AlexC. :-)
pettyofficernick
  • Marineville will be destroyed, Muahahaha.....
« Reply #7 on: September 18, 2014, 12:13:04 am »
I have several 1/8th drills, the oldest is a Pesto, a good British make, and still drills clean, accurate holes. The newest, bought last week as I couldn't find the Pesto, had 'Faithfull' written on it, now blunt and wandering all over the place after a couple of holes in some 1/4 x 1/2 BMS. The Pesto cost about £3.50, the other one 60p, cheap drills = false economy..... ;D ;D
What I do is best not discussed, for I have been many things in my time....
« Reply #8 on: September 18, 2014, 12:50:49 am »
Hold on!  >>:-( ...I thought this was a twisted engineering thread  O0
I also thought PESTO was some sort of Italian GREEN relish that some despots put on sandwiches  {-)
.... Derek
imsinking
« Reply #9 on: September 18, 2014, 09:31:26 am »
PRESTO (what's an R between friends ?  <*< )and DORMER were the mainstay of engineering workshops, it was usually operator 'error' that knackered their stuff, as Nick says "you get what you pay for".
Bill
« Reply #10 on: September 18, 2014, 09:49:47 am »
Agreed Bill.....Dormer were/are the only way to  get what you pay for drill & reamers :-)) ....& even imported to OZ.........Derek
Re: Strength of HSS Drill bits
« Reply #11 on: September 18, 2014, 11:19:09 am »
HSS = Hardly Seems Suitable?!
pettyofficernick
« Reply #12 on: September 18, 2014, 04:43:49 pm »
Sorry for the typo folks, should have read Presto, my mind wanders sometimes to thoughts of food......
imsinking
« Reply #13 on: September 18, 2014, 08:35:37 pm »
Even YOU cant drill a 3mm hole with a sausage roll (smoked or unsmoked)  %%
Bill  :-X
ooyah/2
« Reply #14 on: September 18, 2014, 09:49:59 pm »
Bill  :-X
That made me laugh.
George
Page created in 0.085 seconds with 21 queries.
