May 06, 2025, 10:57:32 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 24 25
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
WHICH GLUE
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: WHICH GLUE (Read 2335 times)
Howard
Full Mayhemer
Offline
Scotter Lincolnshire
WHICH GLUE
on:
August 14, 2014, 08:19:06 pm »
Hi Guys,
I'm wanting to convert a Paula III by using the hull which I think is ABS plastic but the rest will be made from HIP or
plain styrene card but find some plastic glues don't like each other can anyone help with one that will work on both.
Thanks,
Regards Howard.
Global Moderator
Full Mayhemer
Offline
You bark - I will bite!!!
Fareham
Re: WHICH GLUE
Reply #1 on:
August 14, 2014, 08:52:31 pm »
From Aziz Instruction Manual - Page 1:
Glass fibre – Plastic 2-part epoxy or thick superglue
Glass fibre – Metal 2-part epoxy or thick superglue
Plastic- Plastic Liquid polystyrene adhesive (e.g. Revel Contacta Professional or Humbrol Liquid Polystyrene)
Whitemetal – Whitemetal 2-part epoxy or thick superglue
Wood – Plastic 2-part epoxy or thick superglue
Whitemetal – Plastic 2-part epoxy or thick superglue
Window glazing RC Modellers Craft Glue, Weldbond, Clear contact adhesive
Brass – Plastic RC Modellers Glue, Weldbond or thick superglue
Howard
Full Mayhemer
Offline
Re: WHICH GLUE
Reply #2 on:
August 14, 2014, 09:10:59 pm »
Hi bob,
I understand plastic to plastic but joining abs to styrene is not easy if you don't use the right glue, ie liquid poly,contacta and the likes as put my victoria on hold for the same reasons,But thank you for your reply.
Regards, Howard.
Brian60
Full Mayhemer
Offline
Hull,UK-but currently residing in Los Martinez, Spain.
Re: WHICH GLUE
Reply #3 on:
August 14, 2014, 09:25:57 pm »
M.E.K (methyl ethyl ketone from industrial paint supplies) or Plastic Weld from a good hobby shop. Plastic weld contains m.e.k. These are solvents not glue, they work by slightly dissolving the edges to be joined and dry by evaporation (very fast). As they do so the two surfaces become one, rather like a weld seam in metal.
http://www.modelboatmayhem.co.uk/forum/index.php/topic,46369.0.html
Humber Trawler
http://www.modelboatmayhem.co.uk/forum/index.php/topic,49047.0.html
POSH Venture
http://www.modelboatmayhem.co.uk/forum/index.php/topic,53834.0.html
Tramp Steamer
Howard
Full Mayhemer
Offline
Re: WHICH GLUE
Reply #4 on:
August 14, 2014, 10:15:00 pm »
thank you for that Brian,
Regards Howard
AlexC
Full Mayhemer
Offline
West Coast Scotland
Re: WHICH GLUE
Reply #5 on:
August 14, 2014, 10:36:07 pm »
This will do what you require: -
http://www.shop4glue.com/polyweld-57ml-thin-plastic-plas-weld-glue-adhesive-perspex-polystyrene-acrylic-abs-hips-fivestar-51-p.asp
mail order as well.
Best regards.
AlexC.
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
WHICH GLUE
