April 25, 2024, 05:38:26 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Working Vessels
zwarte zee
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: zwarte zee (Read 3001 times)
tugs62
Full Mayhemer
Offline
Blackpool
zwarte zee
on:
August 17, 2014, 07:53:33 pm »
I got this off a mayhem member so thanks Frank
i made a start sanding and removing the glazing this will take a bit of time as doing it between refurbing my crash tender
tugs62
Full Mayhemer
Offline
Blackpool
Re: zwarte zee
Reply #1 on:
August 17, 2014, 09:02:53 pm »
i have also started to remove the deck and scrape the sticky stuff out after this is done i will resin the inside
tugs62
Full Mayhemer
Offline
Blackpool
Re: zwarte zee
Reply #2 on:
August 18, 2014, 05:38:07 pm »
All the deck stripped off
god knows what the stuff is in side the hull it smells like putty
also removed the prop shaft with out to much trouble as is very thin and i dont have any props that fit
will put a new one in later
Full Mayhemer
Offline
Meridian Line, Mouth of the Humber
Re: zwarte zee
Reply #3 on:
August 18, 2014, 05:59:28 pm »
Good Grief
posting scenes like this at teatime
Nearly put me off my snails
Defo a good cleanup job before epoxy
gets near it.
Up Spirits Stand fast the Holy Ghost.
roycv
Full Mayhemer
Offline
S.W. Herts
Re: zwarte zee
Reply #4 on:
August 18, 2014, 07:29:53 pm »
Hi tugs2, is this a Billings Kit? As it seems to look quite large in your piccys..
I am in the last throws of finishing someone elses start of the old and smaller scale Zwarte Zee (1 : 100).
regards Roy
tugs62
Full Mayhemer
Offline
Blackpool
Re: zwarte zee
Reply #5 on:
August 18, 2014, 09:42:49 pm »
hi Roy its only the small one as well 5inch beam but will make a nice boat ive also started to make a new cabins as the old one are a bit past it
sorry Ned i nearly put me off as well
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: zwarte zee
Reply #6 on:
August 19, 2014, 06:40:21 am »
The gunge looks like plasticine.
Barrie
tugs62
Full Mayhemer
Offline
Blackpool
Re: zwarte zee
Reply #7 on:
August 19, 2014, 08:03:59 pm »
Got a bit more done to day i keep sneaking off instead of doing the jobs her in doors has found me to do it always the same get two weeks off and all these jobs appear any way will keep at it
tugs62
Full Mayhemer
Offline
Blackpool
Re: zwarte zee
Reply #8 on:
August 21, 2014, 08:39:34 pm »
Got the prop shaft in today and found this little motor in a old foam plane i used a similar one just a bit bigger in my torben and that goes really well and the battery lasts hours
I keep putting off resin the inside but will have to make that the next job
tugs62
Full Mayhemer
Offline
Blackpool
Re: zwarte zee
Reply #9 on:
August 23, 2014, 09:01:57 pm »
Had a go at soldering today i managed to get it to stick but not very tidy a lot of work filing it now
bit more done nothing is stuck down yet that will get done when all the paint work is done
Print
Pages: [
1
Go Up
« previous
next »
Working Vessels
zwarte zee
