Author Topic: Advice needed guys  (Read 2808 times)
DarrenCarter2
  • Inactive
Advice needed guys
« on: August 18, 2014, 08:25:09 pm »
Got box built for one of my boats what do u think I should do guys paint it or stain in and then varnish I'm going to be airbrushing the name of the boat on the box and putting some foam on the sides for protection and making a stand to go inside so she's fitted fully and safely what do you guys think
Here's some pics of box and boat inside
Brian60
Re: Advice needed guys
« Reply #1 on: August 19, 2014, 04:59:17 pm »
Dunno about the boat but it would make a handy carry box for the dog :} :}
Buccaneer
« Reply #2 on: August 19, 2014, 08:51:20 pm »
I would suggest a coat of Sanding Sealer, smooth it down with 240 then 320 Grit, then Varnish it. If you don't have any Sanding Sealer dilute the first coat with White Spirit, 2 parts varnish and 1 part White Spirit. Sand down as above then 1 or 2 top coats. Don't put neat Varnish straight onto bare wood, you'll never get it smooth.
CGAux26
« Reply #3 on: August 19, 2014, 10:18:37 pm »
Does one side drop down to put the boat in? I used web handles on my last boat box.  Provides a good grip and takes up no space when you push the box up against something.
DarrenCarter2
  • Inactive
« Reply #4 on: August 20, 2014, 07:21:15 pm »
Ok thank u guys for your help I picked up some stuff from b and q today, and no only the top opens I thought it should be ok like that :)
« Reply #5 on: August 21, 2014, 10:13:57 am »
Much, much easier to side load. High probability of snagging the rigging on clothing when top loading (don't ask!) Further you have to bend over. How heavy is the model fully ballasted? Not always an easy manouver.
HTH
Page created in 0.896 seconds with 21 queries.
