You can see that I have already put the motor and battery into the CAD model. There's two reasons. Obviously, I'm designing the structure around the hardware but also, at a later stage, I will get the CAD system to calculate the CG position. The weight of the motor and battery is included in their models.
I spent a fair bit of time considering where to put things inside the boat. One thing that lets down many models is that they look too 'twitchy'. That's because you can't scale time. (Or you can, using video. I've seen some amazing videos on UTube where they are slowed down just a tad and the models look totally convincing). What I wanted to do was increase the mass moment of inertia of the model as much as possible. "Ooo - er," I hear you say. " He's gone off on one....." If you are not familiar with moments of inertia, he's a little demonstration you can do in the workshop or just in your head. Take two hammers - come on, we all have at least two hammers
-. Hold the heads together in one hand , with the handles sticking out. Now try to spin them like an aircraft propeller. OK, turn the hammers round so you are gripping the ends of the handles and the heads are outboard. Now try to spin them. A lot more difficult, isn't it? You still have the same mass (weight) and the CG is in the same place (in your hand) BUT it's a lot harder to get those hammers moving.
I wanted to spread the weight out as far as possible in the boat. The heavy bits are the motor and the battery. The CG on Bluebird is just behind the back of the sponsons. I thought about putting the motor way up front, almost under the forward boom. That would allow me to put the battery a
long way back. However, that would require another hatch between the booms (difficult to seal), there's not much room that far up front to offset the motor and I would need a very long (expensive) prop shaft. The last straw was that all the wiring would lie in completely the wrong directions. I decided to stick with what works on Mk I. The battery is up between the booms but this time it will live in a drawer, designed in front the start. It goes in under the aft boom nicely and this allows me to use my simple hatch. If I can move the motor back a bit (once the CG calcs have been done) I will but for the moment I'm sticking with my existing hardware. I'm back to where I was but at least I'm satisfied that I have explored the possibilities rather than just copy what I did before.
You may notice that in the 'exploded' picture, the cowl frames are solid but in the assembled view, the centres have been cut away. They are two different models of the cowl that are part of the cunning build plan. I'll cover how I plan to build the cowling in another post and let you all rip it to shreds.
Just in case you are thinking I rely too much on CAD I would point out that I could (just about) still generate the design the old fashioned way - drawing it out and projecting all the sections. However, that wouldn't give me a fraction of the information I can get from 3D CAD - and it's much harder! Besides which, I'm not sure quite how well Mrs M would take the installation of an A0 drawing board in the dining room
For now, I need to carry on trimming and fitting the parts together. The solid parts will eventually be used to create 2D drawings as templates for the real wood. (Yes, a set of full scale, printable plans will be posted in due course for anybody that wants to have a go). This thread will grow slowly but I'll try to keep you posted on where I've got to and why I'm going that way.
