Pages: 1 [2] 3   Go Down
Author Topic: A techie challenge....  (Read 12095 times)
U-33
  • K-157 Vepr. Akula-11
Re: A techie challenge....
« Reply #25 on: August 27, 2014, 04:18:33 PM »
That's terrific, thanks for that Ned...much appreciated. Sticks like **** I don't have, must get some tomorrow. Araldite I have...
Thanks again, mate..
J.beazley
  • The building never ends
« Reply #26 on: August 27, 2014, 04:46:02 PM »
Just a thought would it be easier if you put the rudder on the plexan sheet too that way the whole unit can be removed from the bird and your effectively building a hull for the bird superstructure to sit on.
U-33
« Reply #27 on: August 27, 2014, 04:57:21 PM »
Ned...Sticks Like Sh*t ordered online, there was no way I was going into our village diy store and asking for THAT!!
JB...yes, if I'd have thought about it more, I would have done just that, but it's a bit late now. No matter, if it gets knocked off I will change things about.
Thanks gents...as always, much appreciated.
vnkiwi
« Reply #28 on: August 27, 2014, 06:11:02 PM »
Hi Rich,
Think the numbers moulding, is more mould blemishes.
Being blind,old and decrepit was more wishful thinking on my part.
 :embarrassed:
cheers
vnkiwi
U-33
« Reply #29 on: August 27, 2014, 07:23:59 PM »
I went over it with a magnifying glass, VNK, and I couldn't see any numbers anywhere. I think you were getting a touch overkeen there... ;D
vnkiwi
« Reply #30 on: August 27, 2014, 08:20:45 PM »
No numbers Rich, mould blemishes they's where. :D
There's two blemishes, one in front of the perspex, one midway back and towards bottom of photo, so yes, very wishful thinking on my part.
So, now I will walk out under the door, and go inflict my frustrations onto the two cadet draughtsmen, I'm currently training at work.
Poor sods, but they where told at the outset, if they can work with me for the duration of this project, (3 months) then they will be able to work with anyone in the future O0
Where's me hat ma coat {:-{
vnkiwi
U-33
« Reply #31 on: August 28, 2014, 10:05:05 AM »
I pity your two juniors, VNK!!  {-)
U-33
« Reply #32 on: August 28, 2014, 10:31:05 AM »
The OtterBox has just turned up...a very impressive piece of kit. Now I can crack on with fitting it out with the radio, etc. Plan is for an Action low drain, high torque 550 motor, Graupner 4 channel 40mhz radio, Mtroniks Micro Viper esc, Futaba rudder servo and a 11.1v 2250 a/h LiPo battery.
Wish me luck...I'm going in.
HUNTER
  • Hunter
  • Is my cocoa ready yet?
    • Hunter Systems
« Reply #33 on: August 28, 2014, 10:52:07 AM »
Mr H. Go to the toolstation or Screwfix 8) down the Drove and ask for the glue that sticks like s..t IT WORKS!!!!! :D
U-33
« Reply #34 on: August 28, 2014, 10:54:58 AM »
One step ahead, Mr S...ordered it, it should be here in a couple of days. That gives me time to install the radio and generally make ready for the final gluing operations.
Mr H
inertia
« Reply #35 on: August 28, 2014, 01:46:16 PM »
That motor doesn't look like the one you describe; it should have a flux ring right around the case.
Dave M
U-33
« Reply #36 on: August 28, 2014, 01:57:58 PM »
You are quite correct of course, Oh Wise One...I'd taken the ring off for some reason. Anyway, I've changed the motor completely now, it's now got a brand spanking new Carson 'Poison' truck motor installed. By heck as like, but is that a motor, or what?
Being a cocky git, I thought I'd try and stop the shaft spinning....just for research purposes, you understand.   ;D
When I hooked it up to the 11.1v LiPo pack, the only research I could do was to find the antiseptic cream and two Elastoplast...I burnt both the fingers I was holding the shaft with.   <:(
I reckon it'll turn a 70mm prop quite happily...I'll end up with a swan capable of planing!
Nearly finished it now...photies to follow after tea is consumed, ciggy is finished, and fingers stop hurting.   :embarrassed:
U-33
« Reply #37 on: August 28, 2014, 02:42:18 PM »
Tea is now consumed, ciggy is now finished, and fingers...well, they are still hurting <:(  but, you know me, I battle on through the pain barrier.  ;D
Installation now completed, everything works as it should...well pleased with the results. Just going to test the box for watertightness...
Next job...fit OtterBox to the Lexan base plate, and then fit that to the swan.
jarvo
  • Etherow model boat club
« Reply #38 on: August 28, 2014, 08:17:40 PM »
HI Rich
Bit late now. Was going to suggest put the box through the bottom of the swan, i.e. upside down, less drag and less ballast to fit also no worry of your swan turning turtle.
Mark
Tugs are for pulling
U-33
« Reply #39 on: August 28, 2014, 10:24:41 PM »
Initially I did consider that, Mark...but I don't want to cut into the body unless I really definately have to.
I suppose though, if I were to cut a hole in the base just a smidgeon smaller than the box, so it's a real tight fit, then seal it in place with this "Sticks Like Sh*t" stuff, that would do the job securely and safely. With the lid opening from the bottom, access wouldn't be a problem.
I shall sleep on the matter... ;D
jarvo
« Reply #40 on: August 29, 2014, 12:11:52 AM »
HI Rich
The difficulty i see is the prop shaft.
Mark
Perkasaman2
« Reply #41 on: August 29, 2014, 12:29:46 AM »
That rudder looks to be a little on the small side given the size of the birdy and underwater bits. Just a thought.
U-33
« Reply #42 on: August 29, 2014, 07:07:38 AM »
Mark...I've given the matter some serious thought, and for the present, I'm going to stick with Plan 'A'. If it fails, then Plan 'B' will be put into operation. Now I've got this far with the project, I'd like to see it through to the bitter end.
Perkasaman...you could well be right about the size of the rudder, I used what I had in my bits box, didn't give the subject much thought. I'd like to give the bird a trial swim this coming weekend, so we shall see if I need to change the rudder or not.
U-33
« Reply #43 on: August 29, 2014, 12:59:35 PM »
Ok...OtterBox water tested and perfectly ok (after I found I'd pushed the rudder link rod though off centre and created a pin hole in the rubber bellows)
So...do I just glue it direct to the base of the bird's body or do I use the Lexan base, glue that on first, then glue the box to that? What say you, chaps...any ideas/comments/etc?
jarvo
« Reply #44 on: August 29, 2014, 01:20:39 PM »
Thought we had sorted the plate thing.  Glue the box to the mounting plate and screw the plate to the swan, easy to remove to make adjustments, no worry over the glue remaining stuck to the swans bum!!!
Mark
U-33
« Reply #45 on: August 29, 2014, 01:34:52 PM »
I was just checking...making sure you were awake!
jarvo
« Reply #46 on: August 29, 2014, 10:27:33 PM »
HA, awake i was resting my eyes….. one of our members has a duck fitted with a small spray pump, hilarious when the kids get a squirt!!!!!
Get this finished, need to see it in real life???????
Plastic swan real, what was in that coffee?
Mark
U-33
« Reply #47 on: August 29, 2014, 11:00:08 PM »
Done ducks, done a kettle, done a tv set, done a box of rubbish...just fancied a swan. Stand by...next up is an alligator with red led eyes... ;D
http://www.ebay.co.uk/itm/331180494042
Hopefully the swan will be done this coming week, the alligator will be here in a week or so.
« Reply #48 on: August 30, 2014, 07:34:01 AM »
I want one of those!
U-33
« Reply #49 on: August 30, 2014, 07:38:20 AM »
They look good in the water...  https://www.youtube.com/watch?v=GjoTGrFVVGY
Pages: 1 [2] 3   Go Up
