Author Topic: HMS Gloxinia  (Read 17853 times)
Sandy
HMS Gloxinia
« on: August 31, 2014, 08:47:57 pm »
I had HMS Gloxinia out for a sail yesterday:-
All the best
Sandy
marinemole
Re: HMS Gloxinia
« Reply #1 on: August 31, 2014, 09:33:47 pm »
Very nice Sandy, looks good on the water. Hope that isn't the dreaded blue green algae I see in a couple of the shots?
Sandy
Re: HMS Gloxinia
« Reply #2 on: August 31, 2014, 09:53:58 pm »
It is... so bad was it that, despite the pictures, it was very windy and a boat sank.
Tom got out the rubber dinghy but the water was so bad it just wasn't located.
You can't see more than two or three inches down into the water.
TugCowboy
Re: HMS Gloxinia
« Reply #3 on: September 01, 2014, 12:05:48 pm »
That is a beautiful model, great to see on the water like that, thanks for sharing.
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: HMS Gloxinia
« Reply #4 on: September 01, 2014, 03:36:49 pm »
Nice model.
Is it a Revell Flower Class with a massive re-working? It's very difficult to guess the scale.
Re: HMS Gloxinia
« Reply #5 on: September 01, 2014, 03:46:16 pm »
Gorgeous vessel and an interesting name as well! I hope the algae problem is fixed soon.
Sandy
Re: HMS Gloxinia
« Reply #6 on: September 01, 2014, 05:27:26 pm »
It is a 48th scale very long fo'c'sle HMS Bryony (from Fleetscale I think) that had to be reworked to a short fo'c'sle version.
Worked from the photo of Gloxinia from early 1943:-
Uses a small brushless motor (outrunner) and a 6v SLA battery. All works fine as long as you cruise about sedately. Go full chat and the low voltage cut out cuts in and kills the speed controller so it is either a wait-the-drift or break out the waders time. I read the article in MB magazine about why don't scale boaters use brushless and gave it a go. Works fine. At slow speed you can count the blades turning on the prop.
An in progress shot:-
Nice size model but takes quite a bit of ballasting... two 6v SLA's and four sheets of lead.
All the best
Sandy
Re: HMS Gloxinia
« Reply #7 on: September 01, 2014, 09:14:37 pm »
Ooh, lovely crisp styrene work Sandy, she's looking good. The proportions of the hull and sheer look spot on.
Sandy
Re: HMS Gloxinia
« Reply #8 on: September 09, 2014, 06:21:13 pm »
I found that the Flowers, like trawlers, sit very stern low, in other words a lot more draft aft than forward.
I built the stand so that the waterline was level and so sitting on the stand is how the model sits in the water.
But, the Flowers were obviously built on a slipway and as such the verticals; bridge, casing end are all at 90 degrees to the keel.
This means, and it becomes obvious when you look at pictures of Flowers, especially short fo'c'sle ones, that the bridge leans backwards and, despite the stern sheer, the end of the boiler casing does too.
Sandy
Re: HMS Gloxinia
« Reply #9 on: September 09, 2014, 06:36:49 pm »
I didn't take many pictures during construction but the ones I did may be of use to someone:-
Bilge keels
Undercoat
Deck bracing and bilge keel attachment - short brass pins drilled into styrene keels. No expense spared workbench also.
I added the extra portholes.
Re: HMS Gloxinia
« Reply #10 on: September 09, 2014, 10:17:36 pm »
Lovely workshop as well as the corvette! I like the hatches very much with all the latch details etc.
Do you blend glues in the mixer? I under stand the need for a cooker to heat pies in, but I think you could have matched the baseboard to the kitchen :O)
mark w
  • "I stick my neck out for nobody"
Re: HMS Gloxinia
« Reply #11 on: September 12, 2014, 09:54:24 pm »
+1 :-)) . great conversion work, she looks very realistic in the bow on shot.
Mark
"If she can stand it, I can too, play it"
rob
Re: HMS Gloxinia
« Reply #12 on: September 13, 2014, 09:09:43 am »
The Flowers have got to be the most charismatic boats we ever had, really nice model of a really nice boat.
in my own little world
tugboat Tom
Re: HMS Gloxinia
« Reply #13 on: February 04, 2015, 08:34:29 pm »
Have You used  drawings from Fleetscale ?
Are there also drawings of the supersructure ?
Sandy
Re: HMS Gloxinia
« Reply #14 on: February 04, 2015, 09:36:28 pm »
I have some drawings of Aubretia, but none of Gloxinia.
The Aubretia drawings gave me a guide for the plan of the bridge but after that, and in fact for most of it, I worked from the photo.
Not sure of that is very helpful for you?
All the best
Sandy
longshanks
Re: HMS Gloxinia
« Reply #15 on: February 05, 2015, 11:32:02 am »
Hi Sandy,
Great job you've done on her  :-))
Your scratch build work looks superb, what a shame there is not more work in progress pics. Is that a 4" gun where the 2pdr is normally sited?
Looks magnificent on the water
longshanks
Sandy
Re: HMS Gloxinia
« Reply #16 on: February 05, 2015, 04:37:47 pm »
Yes, It is an HA 4inch and the 2dr got moved aft.
Some sources now say it was a 3inch, but original information says it was the 4inch.
The four first Med Flowers all ended up rather unique looking.
It was a nice build, and sails well.
Now working on a 24th scale Fairmile B.
Not sure why I didn't take many photos, as I took hundreds on my (first) Guepratte build...and I have ended up taking even less of the B.  {:-{
All the best
Sandy
longshanks
Re: HMS Gloxinia
« Reply #17 on: February 05, 2015, 07:19:17 pm »
Be interested in seeing any pics of the B
PICKETBOAT
  • PICKETBOAT
  • "History in the making"
    • Chylds Hall Model Shipyard
Re: HMS Gloxinia
« Reply #18 on: February 13, 2015, 09:55:28 pm »
Sandy
Just picked up on these pictures of your wonderful BIG flower class. She looks great, and even better in real life on the water.
Misplaced my password for Model Boat Mayhem, so have not been following things or making comments recently, however I'm up and running again so thinking of posting my next on line build here.
See you at the pond side when the weather warms up a bit.
Steve
Sandy
Re: HMS Gloxinia
« Reply #19 on: March 29, 2015, 11:29:01 am »
Off topic, Kev (longshanks) asked for some pictures of the Fairmile B.
It's been a slow build, but progress as of yesterday:-
ML437 of the Burmese RNVR....
PICKETBOAT
  • PICKETBOAT
Re: HMS Gloxinia
« Reply #20 on: March 29, 2015, 12:01:24 pm »
Sandy
Another excellent build coming out of the kitchen. I shall certainly look forward to seeing this one "beating it" across the lake.
More pictures please.
Re: HMS Gloxinia
« Reply #21 on: March 29, 2015, 05:19:51 pm »
I agree, she is coming along dandy.
longshanks
Re: HMS Gloxinia
« Reply #22 on: March 30, 2015, 10:28:24 pm »
Now that is looking very sweet Sandy  :-))
Keep up the good work
Kev
Sandy
Re: HMS Gloxinia
« Reply #23 on: March 31, 2015, 05:56:20 pm »
Some more pictures:-
Sandy
Re: HMS Gloxinia
« Reply #24 on: March 31, 2015, 06:01:06 pm »
