Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12   Go Down
Author Topic: FISHERIES RESEARCH VESSEL SCOTIA  (Read 97085 times)
DavieTait
Re: FISHERIES RESEARCH VESSEL SCOTIA
« Reply #250 on: January 31, 2019, 03:00:30 pm »
You will need to extend the air pipes then as that was done before she was handed over to the Lab after the accident off Norway , I don't have a photo of that part of the deck to show it but it was literally just cut the pipes in half , weld in 1m of pipe and re-weld to the side of the ship.....
Davie Tait,
Scotland
Seaspray
« Reply #251 on: February 01, 2019, 11:08:26 am »
Davie
I'll look in to it when I am mobile and back on the hobby bench.
Seaspray
« Reply #252 on: April 20, 2019, 06:52:50 pm »
Hi Davie
I am kinda a head of the pictures on this thread. The original plan came from Bill Wood Aberdeen  who built the fiberglass hull. But made enquiries and got a little updated plan from the Scottish Government. So if there is any difference I'll just have to let it go. Seen a picture somewhere of higher goosevents but unable to find it now.
Back with build this week,hopefully
Seaspray
« Reply #253 on: May 04, 2019, 09:59:42 am »
I'm back
Pictures of the two castle builds
pic 1 modern day picture of how the castles look to date
pic 2 using a template to get the the shape and size of side support of castle.
pic 3 the 2 sides cut out ready for to glue into position.
pic 4 sides and  edges glued into position.
pic 5 a clean up and sanding ready for a couple coats of Eze-Kote
pic 6 & 7 offered into position and the tops sprayed up.
More on build soon.
Seaspray
« Reply #254 on: May 06, 2019, 10:21:44 am »
further into the build
pic 1 removed the castle bases and re sanded them as they looked rough on the wood surfaces
pic 2 placed back into place to mark up their position for gluing into position believe it or not they're smooth now
pic 3 before i glued the castles into position i fitted the goosevents into their place
pic 4 - 7 the build of the ladders used to get to the platforms of the castles
Seaspray
« Reply #255 on: May 10, 2019, 12:09:41 pm »
Further into the build some pictures have went missing from the camera.
pic 1 corner of starboard castle being built up
pic 2 rough parts that are in the corner you'll see them later when sprayed up
pic 3 started building the forgot what its called somebody will
pic 4 used plastic as a first build choice but went back to brass main part bent to shape and size
pic 5 support legs cut to size
pic 6 soldered up and primed
pic 7 other parts on the castle being built had to use plastic to get the 'I' beam shape
pic 8 part completed I scraped the plastic top unit
Seaspray
« Reply #256 on: May 10, 2019, 12:34:26 pm »
Castles
Pic 1 you can see the parts on top that were built in previous pictures not glued into position yet Also the ladders
pic 2, 3 start in to fit the railings with 2 views
Took a while to get a good surface on the wood. This is wood used at the time of building the Meteor
Seaspray
« Reply #257 on: May 23, 2019, 08:24:10 am »
Further on with the build
pic 1 the receiving bin glued into position also i added a little power cabinet next to it. sorry about out of focus
pic 2 started to add the support stays after they were sprayed
pic 3 bin completed
pic 4 both castles finished ready for further fittings
pic 5 port castle into position with the crane fitted and the navigation lights you seen the build of the crane earlier in the build
pic 6 container crane fitted starboard side midships build earlier in thread
More later
Seaspray
« Reply #258 on: May 27, 2019, 12:11:32 pm »
When I build the parts of my model I put them away till final build time
pic 1,2 another crane fitted its for heavy duty work as it has two rams
pic 3 rescue and work boats fitted also stanchions and rails
pic 4 the ( lets call it the A frame ) and the gantry now fitted
pic 5 anchor chains sprayed black and fitted
pic 6 forecastle deck has the gooseneck vents / bollards / raised hatches / provision crane / winch room and mast fitted
Seaspray
« Reply #259 on: May 29, 2019, 10:39:26 am »
further build on starboard castle the big heavy duty swing arm unit I was told what this was but I have forgotten maybe D.T came lets us know
pic 1 from the plan the arm roughly cut to shape
pic 2 on it side and sand it  to get the tapper and the straight part at end for arm to sit on square
pic 3 decided to remake the arm in two pieces cut the new shape out thought the top would look better using dowelling
pic 4 this is the main part again cut to use the dowelling on top
pic 5 main part offered into position with more sanding to shape looks up top better with the dowel used
pic 6 that is  a lot better shape and and almost ready to prime
pic 7 finally primed painted glued into position
Seaspray
« Reply #260 on: June 01, 2019, 12:36:01 pm »
starboard castle
pic 1 the rams partly made and taking a measurement prior fitting
pic 2 rams completed made of brass rod inserted in a cotton bud stock ends are larger brass round
pic 3 rams glued in place
pic 4 starboard  castle completed and glue on to the deck
pictures are out of build sequence motto .... don't put your picture into your computer till after you show them   keep them in you camera
Seaspray
« Reply #261 on: June 03, 2019, 06:05:40 pm »
the pelagic split net drum didn't have any pictures on this and the plan wasn't too clear
pic 1 the two ends cut out over size
pic 2 in the dremel run down to correct size and nice flat edges
pic 3 a rough attempt at the drum
pic 4 sprayed up glued into place on the model
pic 5 there is yellow paint section on the inside of the drum ends rather than mask and spray I cut yellow shaped part from a yellow sticky label
next the winches 8 I think
Seaspray
« Reply #262 on: June 10, 2019, 10:10:01 pm »
the winches made from some scrap wood  available
pic 1 started with the drum center of winch
pic 2 platforms cut to size starting to cut round ends out
pic 3 centre and ends cut
pic 4 starting to assemble winches
pic 5 glued together and in clamps over night
pic 6 almost finished build
pic 7 built ready for spraying
Seaspray
« Reply #263 on: June 10, 2019, 10:28:15 pm »
winch continued
pic 1-3 some winches glued into their position on board
pic 4-6 my usual type of name plate for the stand from a piece of branch I got years ago for this purpose
phew almost finished model :-))
« Reply #264 on: June 10, 2019, 10:59:27 pm »
This has been a fascinating build log to date. When I get some spare time I'm going to read the whole thing again and definitely make notes on some of the techniques you have developed during the course of the build. O0
You're almost there Seaspray :-))
Seaspray
« Reply #265 on: June 11, 2019, 07:38:28 am »
Hi Ray
Yes its been a long build but not as long as the Meteor (10 years). Just putting the hull markings on and its a ballast job then of to the local pond for a good long sail.
While I have the Kontio hull lines and a simple G.A. plan plus two build sheets from the Graupner Kit to aid building. I don't think I'll tackle that build. Looking at doing the American Waterways Patrol Launch next. I got it part built up at Coatbridge Model Exhibition. Not so much in depth scale build that'll suit me.
Martin
Seaspray
« Reply #266 on: June 21, 2019, 11:25:32 am »
pic 1 I am using an old pack of Barry's letters for the hull markings
pic 2 started with the line all  the way along the hull or most of it anyway
pic 3 name and port on starboard stern ( Leith is part of Edinburgh docks )
pic 4 more hull markings at the bow
pic 5 my usual name plate a slice of branch and centering  the lettering
pic 6 lettering looks good and 3 coats of varnish
pic 7 overall view of model almost finished
The model has had a good tart up since these pics were taken
« Reply #267 on: June 21, 2019, 11:34:46 am »
She's a beautiful looking model Martin and you can be justifiably proud of your achievement.
Looking forward to seeing pictures of  her on the water :-))
[/size][size=78%]Regards [/size]
[/size][size=78%]Ray.  [/size]
« Reply #268 on: June 21, 2019, 11:51:13 am »
Forgot to add this - don't forget to seal with varnish /lacquer.  :o
Seaspray
« Reply #269 on: June 21, 2019, 05:29:42 pm »
Hi Ray
Cheers for your comment and she does look good so does the real one
 As all the paint is Acrylic and sprayed either from a rattle can or airbrush. I use Chestnut Satin Varnish its just right, sprays easy doesn't run and just good at protecting the model
After using 10 cans over the years and buying from Axminster tools. I found a supply locally and saved £3.00 postage
Martin
Seaspray
« Reply #270 on: June 22, 2019, 09:56:56 pm »
almost there on the build
pics 1-2 in the bath to load up correct ballast
pics 1-7 the completed model
« Reply #271 on: June 22, 2019, 10:06:20 pm »
I think congratulations are in order here Martin, and as I said earlier - she's a real beauty.
With this great model alongside your Meteor you have a fine pair to sail and display.
Seaspray
« Reply #272 on: June 22, 2019, 10:17:37 pm »
Hi Ray
Don't tell anybody there both  going to a Scottish museum. Just a display case issue
Here is a better picture of the magnificent two
Off to the pond tomorrow and trials and final pictures
« Reply #273 on: June 22, 2019, 10:26:40 pm »
Your secret is safe with me  :-X {-)
hama
« Reply #274 on: June 22, 2019, 11:53:20 pm »
Magnificent model! It's been great to follow this build and I particularly like how you make all the different parts and fittings out of wood.
Now looking forward to see her on the water!
Hama
Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12   Go Up
