Not happy with the planned layout of the Scotia.I arranged to go over to Newcastle to see Bluebird (John). I took The Meteor to let John have a look at the finished model as he only had seen it on the Mayhem build. Then we turned to the layout of the Scotia. After some discussing we decided to start from scratch altering the running gear cause access to where it was would be a pain to get to fix or service. Also the rear section of the superstructure (Decks) will now be glued down, leaving a 2 inch hatch on the rear work deck. This'll allow entry to the servo and rudder arm.
pic 1 started with the idea of adding another shaft to the original one. Didn't like this
pic 2, 3 removed both bearings from the shaft
pic 4 started to remove old shaft using the soldering iron. Good job Bluebird advised me to araldite the original shaft in, it was removed with
a little coaxing. Had it been resined it would have been a drill job and maybe not so successful.
pic 5 bought a new 16 inch shaft from MBB fitted motor to mount and to a temporary coupling offered into position to see what else needed to be altered. Cut a notch in centre frame and just managed to fit in, saves moving ESC
pic 6 Fitted motor to mount using stainless steel countersunk screws, nyloc nuts, washers,
pic 7, 8 secured screws by cutting a staple in two, drilling a hole next to the screw head inserting the half staple down the hole and into the
screw slot with a touch of araldite to secure
