Author Topic: HMS Lightning - Torpedo Boat number 1  (Read 7546 times)
joppyuk1
« on: September 20, 2014, 09:44:34 am »
Can anyone point me towards a place to find details of the bow-fitted torpedo tube fitting and mechanism please ? The photos I have seen are not very clear and the drawing I have doesn't show it.
Thank you
colin-d
    • my hobby
Re: HMS Lightning - Torpedo Boat number 1
« Reply #1 on: September 20, 2014, 10:30:37 am »
would it be this Version of HMS Lightning..??
http://commons.wikimedia.org/wiki/File:HMS_Lightning_1876_model.jpg
joppyuk1
« Reply #2 on: September 20, 2014, 01:58:39 pm »
That's the one. My problem is that the mount looks far too simple as it stands. Surely it must be more than a couple of triangular supports on a turntable, and firing must be more than just pushing the pole sticking out the back? Perhaps I'm overcomplicating something that was fairly new technology at the time.
tghsmith
« Reply #3 on: September 20, 2014, 04:11:54 pm »
http://books.google.com/books?id=YDzWQbUP3sUC&pg=PA165&dq=whitehead+torpedo&hl=en&sa=X&ei=d5QdVNfuMMeRyATuq4HYCw&ved=0CD0Q6AEwBA#v=onepage&q=whitehead%20torpedo&f=false     as in early one offs, good documents are hard to find, I suspect that the twin mount was derived from the early mount you need, the long tail on the tube shows up in "brotherhood" designs on some later tubes. have seen an early french book on torpedos that also contained some good drawings..
« Reply #4 on: September 20, 2014, 04:18:23 pm »
I don't think the "pole" sticking out the back end was for firing the torpedo, rather for actually directing the track of the torpedo, as the whole tube was able to move around on the carriage below the supportive brackets.
TailUK
« Reply #5 on: September 20, 2014, 04:18:43 pm »
Any one modelling Torpedo boat of this era should check out Chylde's Hall Model Shipyard,  http://www.chyldshallmodelshipyard.com/
They have a deck mounted torpedo tube in their catalogue which looks a lot like to one on this model.
The pole shown on that tube is probably a black powder "impulse" tube.  This was basically a cannon fixed to the end of the tube which was loaded with black powder and "fired" the torpedo out of the tube.
« Reply #6 on: September 20, 2014, 04:24:44 pm »
if you enlarge the photo you will read that the torpedo was fired via 180 psi of compressed air, not black powder nor just pushing the pole???..
always pays to read the info. %% %% %%
TailUK
« Reply #7 on: September 20, 2014, 04:30:57 pm »
If you read up on Whitehead torpedos it say "either compressed air or black powder" so it was a even chance and powder or air the principle is the same.
« Reply #8 on: September 20, 2014, 04:34:21 pm »
yes, might be so, Tailuk, but on this particular model  which joppyuk wishes to make.......it was compressed air???.........so the info may as well be right, and as such there would probably be pipe work and levers to fire the torp showing on deck, and I think it is this info that he requires.
TailUK
« Reply #9 on: September 20, 2014, 04:38:58 pm »
The piping would come up through the pivot point of the tube so as to allow the tube to rotate for reloading.
« Reply #10 on: September 20, 2014, 04:46:58 pm »
If you read a bit more Neil, it states the firing gear was located in the conning tower.
« Reply #11 on: September 20, 2014, 04:58:44 pm »
 :-)).....never got that far, Ned, {-) {-)
joppyuk1
« Reply #12 on: September 20, 2014, 06:43:23 pm »
I'll be chasing up the book through the library, thank you. Already have a tentative enquiry to the NMM. Such a simple query and already there's a lively discussion. If I can get the information I need, then there will be a model, but don't hold your breath. I find the research takes as long as the build, and I've only just started.
tghsmith
« Reply #13 on: September 20, 2014, 06:58:57 pm »
building without the proper research most often results in rebuilding..
tobyker
« Reply #14 on: September 20, 2014, 08:20:07 pm »
reloading the tube must have been fun anywhere but up the Beaulieu river!
joppyuk1
« Reply #15 on: September 23, 2014, 10:56:04 am »
For a number of reasons this project will not be going ahead. Therefore I have a couple of NMM drawings for sale (see relevant section of forum).
Page created in 0.288 seconds with 17 queries.
