Author Topic: Interesting , if difficult , warship to model...  (Read 2714 times)
DavieTait
« on: September 25, 2014, 05:51:22 pm »
http://www.solarnavigator.net/boats/ghost_stealth_fighter_ship_juliet_marine_systems.htm
They're claiming they use supercavitating technology ( means having a very powerful bubble maker right at the tip of each hull so the bubbles reduce friction , Russia has the Skval torpedo capable of 250knots that uses it ) but I would bet that in anything other than a flat calm this thing would be pretty unstable and very uncomfortable to be aboard
Davie Tait,
Scotland
Umi_Ryuzuki
    • Models and Miniatures
Re: Interesting , if difficult , warship to model...
« Reply #1 on: September 25, 2014, 06:00:21 pm »
A bloke form Australia built one.
Paul, built an early design rc model in...2007?
http://www.rcgroups.com/forums/showthread.php?t=725628
video :)
http://www.rcgroups.com/forums/showthread.php?t=1364627
 :D
Because it uses SWATH, it should be a fairly stable hull in the high leg mode.
More recent reports on this privately funded project show some performance value.
http://www.youtube.com/watch?v=6RuJ1vdjrMg
« Last Edit: September 25, 2014, 06:21:24 pm by Umi_Ryuzuki »
« Reply #2 on: September 27, 2014, 07:06:10 pm »
Looks like a shuttle from NCC1701  {-) (enterprise), I think they would get better results from designing a high speed sub based on nature, capable of flying to reasonable depths with extreme manoeuvring for dodging would be attackers, than this.
raflaunches
  • The Penguins are coming!!!
« Reply #3 on: September 27, 2014, 08:09:06 pm »
Judging by the complexity it would probably spend more time being repaired than actually doing anything important. One fault in the sponson and it'll either seize in that position or collapse, either way conventional hulls are safer and easier to maintain.
As for stealth, you can still see and detect a wake, and judging by the picture I can't imagine a wake like that staying hidden for long!
Nick B
Illegitimi non carborundum!
dodes
« Reply #4 on: September 27, 2014, 08:59:32 pm »
Hi Nick, myself I think it is an interesting innovation using swathe tech for a more stable platform and pioneering the bubble cavitation tech for a faster more efficient water/hull friction tech for a faster hull and increased fuel efficiency, interesting to see where this will lead to.
raflaunches
« Reply #5 on: September 27, 2014, 09:35:27 pm »
Innovative-yes, practicality- probably not .
Same reason why you don't see many hydrofoils in military service anymore, any damage to any of the foils leads to inefficiency or worse- catastrophic failure. Too easy to damage in active service.
What if only one leg deploys when they need to get away? Innovation is good but often it leads to something that's a fad only to be retired in less than 10 years.
Nick B
« Reply #6 on: September 28, 2014, 01:48:47 am »
The great thing about crazy inventions is that they sometimes trigger new ideas, and better ways of achieving the concept.
Some of these come into fruition, like the 'flying bedstead', and I am certain that the Osprey aircraft went through many iterations.
And swing wing aircraft? Crazy idea! That will never catch on.
« Last Edit: September 28, 2014, 01:51:07 am by tigertiger »
Z750Jay
« Reply #7 on: September 30, 2014, 07:06:55 pm »
It would be interesting to build though I might stick to BAE Systems Halmatic Interceptor Craft as a build.
Mainly as it was being worked on right next to the minesweeper I was working on today.
