Author Topic: esc  (Read 4001 times)
regiment
esc
« on: September 27, 2014, 01:09:52 pm »
trouble with my montronic esc red and green lights not flashing (no jokes) only red light comes on  motor not turning rudder ok new tx rt  sent it for check came back this morning invoice saying all checked and working put it back into boat guess what up no green only red staying on so  will be  sending it back for recycling  on Monday   unless some one knows better
U-33
  • K-157 Vepr. Akula-11
Re: esc
« Reply #1 on: September 27, 2014, 01:27:42 pm »
Give Mtroniks a call, they will help you out over the phone, tell you what to do. They are very good like that.
regiment
Re: esc
« Reply #2 on: September 27, 2014, 01:39:57 pm »
hi u33 just got it back from montroniks £5 for nothing said all ok
Re: esc
« Reply #3 on: September 27, 2014, 03:05:04 pm »
What tx rx are you using Gordon?
Is the esc a plug and play or does it have
asetup button?
regiment
Re: esc
« Reply #4 on: September 27, 2014, 03:33:51 pm »
hi 27 mh   plug and play tried every thing except the hammer
Re: esc
« Reply #5 on: September 27, 2014, 03:43:30 pm »
Just switch the Tx on first make sure the throttle is central.
Switch on the esc and receiver and move the throttle
slowly forward.
You should then get a green.
If you get a red then you must reverse the Tx setting for
the throttle.
Re: esc
« Reply #6 on: September 27, 2014, 03:57:46 pm »
Does it work now?
Re: esc
« Reply #7 on: September 27, 2014, 04:16:58 pm »
Gordon , If you have a solid red led on the ESC it means no signal
from the RX.
If as you say the rudder servo is working, then double check the
esc lead is in the right socket on the RX.
Common mistake made by most of us at sometime is to push
the esc connector plug alongside the pins on the Rx so no connection.
regiment
Re: esc
« Reply #8 on: September 27, 2014, 05:29:09 pm »
hi  after walking half a mile to my friends house with the boat etc  I let him have a go looks like the hobby receiver is  playing up put one of his in boat all ok  so looks like more exspence   think I will go back to paper gliders  cheaper
   thanks for all your help  gordon
Re: esc
« Reply #9 on: September 27, 2014, 06:46:14 pm »
27mhz rx in the post to you when I get home Monday  :-))
regiment
Re: esc
« Reply #10 on: September 27, 2014, 07:36:04 pm »
hi  thanks very much for your kind offer will put a few bob  in local rnli box    gordon
