Author Topic: Joffre motor selection  (Read 3696 times)
Terry
« on: October 19, 2014, 04:47:18 pm »
Hi all, my winter project is a Caldercraft Joffre, not arrived from Blighty yet, but I am already thinking about one of these to power it. Any comments welcome.
http://www.mtroniks.net/prod/Boat-Speed-Controls/G2-Hydra30-System.htm
Re: Joffre motor selection
« Reply #1 on: October 19, 2014, 05:30:31 pm »
I don't know  anything about brushless motors except that they can rev very highly............but I wouldn't hae thought that revs were needed on an old steam tug..........a 3 quid 385 motor and 15 amp speed controller would be ample for the Joffre.....sailed my puffer.......equal size for years on one. neil.
« Reply #2 on: October 19, 2014, 06:19:59 pm »
The last one I fitted out I used a low drain 545 motor on 6 volts.
As Neil said cheap.
Calimero
    • Calimero's RC shed
« Reply #3 on: October 19, 2014, 07:49:26 pm »
What's the prop diameter on that tug ?
50mm I assume ?
Even under 6V that 1000kv motor would be too fast. For a 50mm prop on a tug, shaft rpm should be around 3500, tops. On a steam tug you could probably go down to 3000 rpm. That would be a 500kv motor under 6V.
My next twin screw springer with 48-50mm props (in Korts) will get two 620kv motors under 6V but I intend to do some heavy towing ...
« Reply #4 on: October 19, 2014, 10:28:47 pm »
Or use a smaller or less pitch prop.
These smaller models can be powered quire successfully on 3 blade plastic props.
oldiron
« Reply #5 on: October 22, 2014, 03:29:00 am »
In my Joffre, I used a Decaperm I had sitting on the shelf. Plenty of power:
http://www.modelboatmayhem.co.uk/forum/index.php/topic,42151.0.html
Subculture
    • Dive-in to Model submarines
« Reply #6 on: October 22, 2014, 05:20:17 pm »
Decaperm doea bout 3kRPM unloaded doesn't it?
So if going brushless you would want a low kv set-up, about 500kv for a 6 volt system and 250kv for a 12 volt.
Geoff C
« Reply #7 on: October 27, 2014, 06:14:06 pm »
Hi,     I'm going to power my 36in. tug Empire Raymond with an Mtroniks M500 motor, a 6volt 4amp SLA battery, an Mtroniks Marine 15 ESC, all driving a 65mm three blade plastic prop.
All my senior moments seem joined together these days.
nick_75au
    • Logan City Marine Modellers
« Reply #8 on: October 27, 2014, 07:26:18 pm »
The motor in the OP will drive a 50 mm prop at 6 volts but is a bit fast, A hobby Kink DT700 will work really well, its 700 Kv but in a bell motor rater than an oversized outrunner that usually has the low Kvs, the other option is some of the newer multi rotor motors are getting down in Kv whilst not being 3000 watt monssters
http://www.hobbyking.com/hobbyking/store/__6246__hexTronik_DT700_Brushless_Outrunner_700kv.html
http://www.hobbyking.com/hobbyking/store/__41623__4108_380KV_Turnigy_Multistar_22_Pole_Brushless_Multi_Rotor_Motor_With_Extra_Long_Leads.html
Geoff C
« Reply #9 on: October 28, 2014, 04:01:26 pm »
The Mtroniks M500 motor, 4.8 - 13volts   16000revs at 12volts
Page created in 0.105 seconds with 23 queries.
