Pages: 1 2 [3]   Go Down
Author Topic: Xrad's Brooklyn Tug  (Read 23090 times)
xrad
  • Keeper of the Sun Dried Tomato
Re: Xrad's Brooklyn Tug
« Reply #50 on: December 08, 2014, 02:34:13 am »
Thank you SteamUp and Antipodean!  If you liked that one, you will love this pic.  flouquil weathered black (the best weathered black I have used)  surrounds rust scrapes; scuppers hand made from brass, oozing rust and dirt, rusty chains; and hand woven jute line with flayed tassels (w/some seaweed for good measure!)
Tip: for those of you new to painting, I think that what makes this a great model to build is that you can 'Age' the boat.  I was shooting for end of life steamer.  In order to get the aged look, it takes time.  primer, original hull colors, some light ageing, repairs, dents, weathering,4 washes, touchup, repainting base  colors in spots , rust, and re-covering with spot touch=ups. final coating with testors dullcoat as a protectant and to bring down any highlights...kind of levels the finish.  Also, Painting done above and below the waterline.  It is not all done in one sitting.  probably took at least 2 weeks altogether.  It's like writing a story, you keep going back and rewriting and rewriting until everything sits well.
Still have a few more little things like axes to make and a few 1/32 seagulls...but 99.9% done!
Planning next project which could be a pilot schooner...or a model bash of a mahogany 1930's racer...or maybe a steam trawler that needs completing...who knows....
Hope you guys enjoyed the build.....
I will try to post better pics soon.  And of course, once the weather warms up, out on the pond for some steaming  :}
« Reply #51 on: December 08, 2014, 04:02:02 am »
xrad.......I have been watching & reading every posting in the build  O0......
The last image takes the cake.......congratulations of the final weather worn image ..it is also very warm :-)) Derek
steam up
« Reply #52 on: December 08, 2014, 10:57:46 am »
I have enjoyed your build very much looking forward to that video (just put a hat on lol). :}
« Reply #53 on: December 08, 2014, 04:31:17 pm »
Weathering par excellence.
Waiting for the wet run :-))
Needs a foggy lake/pond and
a low low camera to really show
her off.
xrad
« Reply #54 on: December 14, 2014, 10:08:06 pm »
Wow, thanks guys! Really glad you enjoyed it.  Absolutely finished now with rope and axes and life preservers with proper mounts and all.  Also fine tuned the throws on the servos for the F/R gear on the engine. Needed to make servo arm extensions to get the right ratios. And the 'spring return' to neutral and 'steam off' is a nice feature that I am getting used to and liking.  I can just fire her up in about 5 min to steam and easy peasy, runs smooth F and R!  Just waiting for a nice day now for better pics...should be sometime in April....
steam up
« Reply #55 on: December 15, 2014, 01:15:41 am »
April April we can't wait till APRIL >>:-( >>:-( >>:-( LOL.
xrad
« Reply #56 on: March 31, 2016, 09:38:56 pm »
Started a stand.....need to trim the foam a bit more....
xrad
« Reply #57 on: March 31, 2016, 10:24:10 pm »
done......for now....
TIP:  Lay the keel blocks first, sand down where needed and get the keel to lay well.  Then, I drilled 1/2 way through the base w/ 5/8th wood bit for the third support log from the front( one on each side). Then ONLY these logs were cut to perfect length to keep the hull from heeling, fitting them into their respective holes.  Marks made for the other 5 posts on each side. Then I drilled all the way through the base for each remaining post at the marks. Beveled one end of each log to abut the hull, and passed the log up from the bottom of base, cut to length, and then glued in place(save the sawdust/chips for dressing up the log bases). REAL easy to get all the other logs perfect length with this method! All logs are 5/8th except the rear logs, which are 1/2.....then a little airbrushing and some ho scale grass....
KNO3
« Reply #58 on: April 01, 2016, 10:58:39 pm »
Nice idea. I should try that for my tug as well.
xrad
« Reply #59 on: April 06, 2016, 05:26:24 pm »
Thx KNO3.
Tug and launch on display at major local business.  Much interest, but I don;t think it's enough to start a local model boat group. Poor pic quality due to my flippy phone...
Pages: 1 2 [3]   Go Up
