Author Topic: Research new project Taklift 6  (Read 4022 times)
david48
« on: October 24, 2014, 10:42:18 am »
Still not allowed in to shed after the hip op ,so Fairmount is still on hold .I have had a bit of a plan to make something to tow and a have come up with Taklift 6 . Now this is where the brain wil not engage . Fairmount is built to 1:75 Ok so far . I would like the crane to be the same , I know I should be able to work all this out but cannot convince my self I am right .
From the spec sheet  the barge is 72.56 mts long , 30.50 mts beam ,5.50 mts deep ,please can someone tell me how to work it out  or what would be my build diamentions.
This lifter is on the Forth Crossing for the next 3 to 4 months so I might be able to get more pictures as well as useing the wonder web
Thank you
David still not building Fairmount Alpine
Calimero
    • Calimero's RC shed
Re: Research new project Taklift 6
« Reply #1 on: October 24, 2014, 10:57:17 am »
72.56m / 75 = 96cm or 38"
30.50m / 75 = 40.6cm or 16"
5.50m / 75 = 7.3cm or 2.9"
david48
« Reply #2 on: October 24, 2014, 11:08:55 am »
Thank you for your help , I could not convince my self , I was in the right ballpark nearly  .Taklift is self propelled but I will not do that But try to get the crane/sheer legs to work . Now with your help I will be able to work out other sizes
Thanks again will start to rough out some plans ,this could be sometime
David
Calimero
« Reply #3 on: October 24, 2014, 11:14:31 am »
Always nice to have something to push around ! And a working crane would be pretty nice too.
I'm building a barge from my springer tug. Will be around 47" by 16". Not sure what I'll put on deck.
I already have a 17" air horn and compressor to scare off ducks on the pond.
Brian60
« Reply #4 on: October 24, 2014, 05:51:19 pm »
Here's an online calculator for you
http://scalecalculator.appspot.com/
Just put in your values, change the output scale to what you require, ie 1.75 and it will do all the work for you.
Or a fully downloadable one here............
http://www.clubhyper.com/reference/calculatorfc_1.htm
poll
« Reply #5 on: October 24, 2014, 10:06:44 pm »
    Hi David 48
   This is a photo of Taklift 4 at Ellesmereport show.
radiojoe
« Reply #6 on: October 25, 2014, 12:24:16 am »
So good to see all the tugs working together, it must have been great fun.  :-))
david48
« Reply #7 on: October 25, 2014, 09:31:06 am »
Please can some one tell me who the builder of Taklift 4 is . I would think the builder made his own plans ,am I right .
David.
Brian60
« Reply #8 on: October 27, 2014, 12:30:59 pm »
  David this link should be of use to you. It is of the crane barge (sheerlegs) Cormorant. Its a PDF document that can be downloaded and down at the bottom of it  are line drawings of the crane barge, it should be a simple job to scale them to what you require.
http://www.multraship.com/dbdocs/fleet_33_attachment.pdf
david48
« Reply #9 on: October 28, 2014, 11:10:42 am »
Thank you Brian56 for the PDF it gives a good deck layout. I can not get back to Fairmount Alpne yet just been to the Physo she says I can not resume normal service for another 3 weeks Its a no no sitting on a office chair after the hip operation.
David
Page created in 0.043 seconds with 21 queries.
