Author Topic: Help Needed Vitoria Rigging  (Read 4040 times)
« on: November 08, 2014, 06:34:07 am »
I have been given a Victoria sailing thingy which came with the rigging looking like a snakes honeymoon. It has the sail arm servo and all the bits inside, however I have no idea how the saill winch should be connected, or indeed how the gib is fixed, any help would be most welcome.....or it gets a steam plant {-) {-)
rickles23
    • Royal Navy Commandos
Re: Help Needed Vitoria Rigging
« Reply #1 on: November 08, 2014, 07:07:38 am »
Need a photo so I can see what is what as setups for yachts differ from person to person. Meanwhile I'll see is a diagram for your type of yacht is available.
rickles23
« Reply #2 on: November 08, 2014, 07:10:54 am »
« Reply #3 on: November 08, 2014, 07:11:59 am »
Mng PHIL bring it with you next weekend   O0
« Reply #4 on: November 08, 2014, 07:27:47 am »
many thanks rickles23, that is a very good and helpful link,
With luck Stav we should be able to sail it next weekend
rickles23
« Reply #5 on: November 08, 2014, 12:54:00 pm »
That's ok it's what modellers do. Fair winds.
« Reply #6 on: November 08, 2014, 02:12:49 pm »
http://www.fpyc.ca/Vicman.pdf
This may be of use.
Klunk
« Reply #7 on: November 08, 2014, 05:46:53 pm »
Should have said when I was there today Phil. I could have rigged it for you while at the show!
full time penguin
triumphjon
« Reply #8 on: November 09, 2014, 08:44:14 pm »
good luck , ive just finished rebiulding one which i got just over a month ago , one of our club members has one , after a short conversation with him he told me the sail arm servo requires to have more grunt than fitting the recomended 3kg/cm standard sized servo , to this end ive fitted a whirlwind drum winch , ive also made my own sails using the original very frayed mk1 suit as patterns , made a new mast with bottlescrew kicker and swapped the jib boom for a 6mm od alloy tube , only finished at lunch time today , no photos yet & ive not had it in the water either !
