Author Topic: hms hood 1/128  (Read 12629 times)
timmer
    • Facebook
hms hood 1/128
« on: November 17, 2014, 09:11:11 pm »
Ok so ive been given the green light by the boss to get myself an xmas present. Im looking at the fleetscale 1/128 HMS Hood semi kit. Its about the size im looking for and should give me plenty to reserch and get my teeth into for 2015. I just wonder (before i part with so many hard earned £££) if anyone has dealt with fleetscale and what their Hulls are like etc etc. Any help would be very much welcome.
cheers
Tim
rob
Re: hms hood 1/128
« Reply #1 on: November 17, 2014, 11:39:48 pm »
Never had a problem with Fleetscale myself.
Give them a ring, I'm sure they will belay any of your fears.
in my own little world
John R Haynes
Re: hms hood 1/128
« Reply #2 on: November 18, 2014, 08:29:09 am »
I have just completed   a 1/128 HOOD for a client . Took the best part of this year ! My build with Fleetscale's terrific hull is in my Portfolio section on my site [ www.johnrhaynes.com ]
 I developed many fittings which are shown on the model. Its a BIG model to build .
rob
Re: hms hood 1/128
« Reply #3 on: November 18, 2014, 08:35:21 am »
Beautiful job
timmer
    • Facebook
Re: hms hood 1/128
« Reply #4 on: November 18, 2014, 04:00:23 pm »
Thankyou for the advice gents. I've ordered the hull and extra fittings set today.  :-))
timmer
    • Facebook
Re: hms hood 1/128
« Reply #5 on: January 26, 2015, 08:04:03 pm »
   What with xmas and all that has come along ive been a bit rubbish at updating and taking photos but i thought now would be a good time to update everyone with where i am. The build is as difficult as expected but im loving every minute of it. As you will see by the pictures, ive got all the internal electronics and running gear sorted. Just got to install the rudder servo. I didnt realize there would be so much space to play with in the bow section so i think it would be an injustice if i don't get at least one of the turrets moving and maybe a working anchor winch. Anyway my build skills are quite novice but im improving so really looking forward to progressing with this bulid. Hope you enjoy.
timmer :-))
Re: hms hood 1/128
« Reply #6 on: January 26, 2015, 08:12:37 pm »
Cant help noticing one little boo boo if you want to call it that......seriously it is not good practise to use crimps on the motor connections.............WHY...well if there is ANY movement at all it will cause arking and it will eventually lead to a failure of a motor or even all of them....YES I know it is slim but whilst you got no deck on her solder the wires on to the motors ...it iwll only take a couple of mins
timmer
    • Facebook
Re: hms hood 1/128
« Reply #7 on: January 26, 2015, 08:18:08 pm »
Thanks dave. My plan was to solder them but the moters have been in and out and in again so much that the crimps have stayed. Will certainly be soldering them now though. I didnt realise that it could have caused such a problem. Thank you again for the advise  :-))
Re: hms hood 1/128
« Reply #8 on: January 26, 2015, 08:41:45 pm »
The electrics are impressive! I like the frame work as well.
Re: hms hood 1/128
« Reply #9 on: January 26, 2015, 08:59:32 pm »
Hi timmer....is that a 100 diameter cooling fan over the power yoke board?...and is it sucking or blowing?
If it is blowing...the hot air will be forced onto the component on the PORT side of the power yoke board.......
To make good use of air transfer convection you really need a form of open exhaust x approx. twice the [total] surface area [diameter] of the fan...thus to minimize pressure drop due to restriction
Again from memory...DM [Inertia] provided a table here on MBM on optimal core sized motor wiring for low voltage DC applications  O0 ...would be worth reading :-))....
timmer
    • Facebook
Re: hms hood 1/128
« Reply #10 on: January 26, 2015, 09:56:52 pm »
Thanks Derek
   I can kinda see where your coming from. Do you think it would help if I vented the superstructure and maybe incorporated a fan blowing down into the hull?
Timmer
Re: hms hood 1/128
« Reply #11 on: January 26, 2015, 10:08:00 pm »
If it is in the right place perhaps one of the funnels would act as an outlet?
Re: hms hood 1/128
« Reply #12 on: January 27, 2015, 12:50:02 am »
timmer... as suggested by ballastanksian .... one of the open funnels could be an ideal exhaust as it would also contribute to a venturi effect which is preferable and more effective to an open hatch or skylight
Alternatively your thought of an additional smaller fan possibly in the other chimney pushing/drawing air into the superstructure sounds fine
We can also see the smoke foggy unit just aft of the power choke board...would warm air assist or hinder the effect of this unit?
Now I am not suggesting you commence smoking cigarette's  <*< but the only real way to confirm air direction and draw function is to use some form of smoke  ;)
You have plenty of choices...so carry on with the good work  :-)) ...& keep us posted with more results & images as you progress ...... Derek
timmer
    • Facebook
Re: hms hood 1/128
« Reply #13 on: February 03, 2015, 05:59:29 pm »
Been getting on with the superstructure. Ive had to employ a bit of artistic licence to fit in the access to the hull but i think it looks ok.
Re: hms hood 1/128
« Reply #14 on: February 03, 2015, 07:11:22 pm »
ooh, that is coming along sweet. Keep on inspiring us!
radiojoe
Re: hms hood 1/128
« Reply #15 on: February 03, 2015, 07:32:50 pm »
Hi Timer, some fine styrene work there, and very neat cutting out of openings, I know that's not easy, as for artistic licence I don't know where I'd be without it,  %%  following your build of this iconic ship.
timmer
    • Facebook
Re: hms hood 1/128
« Reply #16 on: February 11, 2015, 02:36:46 pm »
havent done a great deal to the ship over the last few days but i now have a nice clean workshop :-)) :-))
I did manage however to get a test tank built in the garden. (hood wouldnt fit in the bath)
Re: hms hood 1/128
« Reply #17 on: February 11, 2015, 09:57:02 pm »
Will the holes have spyglasses in them so you can see what the hull does underwater or will they have cocks to drain the water out?
It looks bloomin brilliant, I will suggest this to a friend who only has a shower!
timmer
    • Facebook
Re: hms hood 1/128
« Reply #18 on: July 26, 2015, 08:51:19 pm »
I know its been a while but Ive been very busy with a lot of other things so the Hood unfortunately has had to take a back seat. Finally for the first time in a long while Ive managed to clear the shed and make some time to carry on.  Hope you like the pics. There will be more to come.....hopefully
Re: hms hood 1/128
« Reply #19 on: July 26, 2015, 09:02:31 pm »
I have removed your first post with the missing pictures   :-))
ken
timmer
    • Facebook
Re: hms hood 1/128
« Reply #20 on: July 26, 2015, 09:12:47 pm »
Thanks ken. Been so long i forgot which thing to press on the website.  ok2
Re: hms hood 1/128
« Reply #21 on: July 26, 2015, 10:15:35 pm »
Just 1 small comment that I noticed when looking at the first pics.
The Aeriel for the receiver looks low in the hull and surrounded by metal.
Could you raise it higher within the hull?
Dan.Lord
Re: hms hood 1/128
« Reply #22 on: July 26, 2015, 10:47:48 pm »
Really nice looking build  :-))  very neat superstructure work , most envious  :embarrassed:  Looking forward to seeing her progress  O0
timmer
    • Facebook
Re: hms hood 1/128
« Reply #23 on: July 26, 2015, 10:50:09 pm »
Hi Bob
   Thanks for the observation. I've already raised the receiver so it  sits just inside the opening. I'm thinking of bringing it up a bit further along with some power switches so I've no need to keep opening hatches to turn on.
radiojoe
Re: hms hood 1/128
« Reply #24 on: July 27, 2015, 12:26:16 pm »
Hi Timer. Your work maybe slow, but I can't fault the quality, I always have the RC switch on deck, I connect a rod to the switch below decks the rod passes though the deck and I disguise it with a mushroom vent that doesn't look out of place just about anywhere, then just lift the vent to switch on.  :-))
